67 camaro swap, no spark
I'll try to keep this short. I have a 67 camaro with an Ls1 and a T56. The car was running, even drove it around the block. Had a better tune flashed on it and installed new injectors in preparation to get tuned this weekend. Now I have no spark. Here are the details.
411 pcm
checked all fuses and relays
checked all grounds
58 psi fuel pressure
replaced crank position sensor
injectors fire - checked with noid lights- plugs wet with fuel
coils have 12volts going to them with key on and cranking
coil signal wires only have around .2 volts when cranking
I don't know what else to try. Looking for suggestions. Thanks
411 pcm
checked all grounds
Can you run a jumper wire to the coils from either a keyed source or from the battery and see if the car fires and runs? If it does I'd look to see if a terminal on the ecm that allows the coils to get voltage has either been damaged or if the ecu is damaged.
411 pcm
checked all grounds
411 pcm
checked all grounds
Crank sensor was replaced according to first post, BUT even new ones can be bad. Use GM parts...
The following users liked this post:
Jimbo1367 (06-10-2022)
G Atsma (06-09-2022)
I had a no start issue with my swap. Took a couple days of agony to figure out. I put a new crank sensor in, after the 4 days of exhausted options I said what would it hurt to throw the old one back in. And sure enough it fired right up. So, id grab another crank sensor just for the hell of it to see. You can always return it.
G Atsma (06-10-2022)
I did check it under load. I don't remember what the exact numbers were, but there was not much difference. I also checked the signal wires to the coils while cranking. I only had about .20 volts there.
Put the new 60 lb injectors in . Maybe the old tune with the old injectors were rich. Had Matt Happel, my tuner, over checked and tried a bunch of things. It stumped him too. They were definitely wet with fuel. Put the new plugs in and immediately ran.
G Atsma (06-14-2022)
