Who is considered a Chevy Performance LS crate engine guru?
What are you trying to find out? The guys at Scoggin Dickey in Texas would be a good resource.
The following users liked this post:
wannafbody (07-26-2022)
I am waiting 6+ months for an LS376/525, keeping things as OEM as possible is a top priority in this case, so I am looking for a workaround...and a cam/spring swap is an easy enough job, but I need to know exactly what hardware is required to convert a stock LS3 to a LS376/525.
I am trying to get a full, detailed list of the hardware differences between the LS376/525 and the E-ROD/stock LS3...down to the fasteners if applicable.
My understanding is there is no difference in any of the parts between the E-ROD and stock LS3, other than whatever CA emissions parts they throw in the E-ROD box, plus the E-ROD calibration program/tune would be different. So whatever parts required to convert one into an LS376/525, should also be the same for the other engine. (I have my own exhaust, oil pan, and an accessory package ready to go).
The ONLY difference between the 430, 480, and 525HP LS3 is the cam. That's IT. And a crappy cam at that. Same lifters, pushrods, springs, retainers, keepers, etc.
Get a 430HP LS3 and put a GOOD cam in it.
Yep. Note that the ASA and Hot cams have less lift than the stock LS3 cam. (All are 0.525 on the exhaust, but the LS3 is .551 on the intake. The others are .525 on both)
A hot cam is around a 219/228 on 112, an ASA cam is around 226/236 on 110, I believe. They seem to not be fun to tune and really over no benefits, other than you don't need new springs. There are similar duration cams throughout this range that will have more power, smoother power, take better advantage of the head flow of an LS3 head.
G Atsma (07-26-2022)
If you like the general spec of the hot cam, check into the Summit 8720R1.
Very similar specs EXCEPT it has .600 lift, plus it is ground on better lobe profiles.
And the $270 price tag doesn't hurt too much either....
I had the ASA cam in a 5.3L and swapped to the Ghost cam and saw excellent results. I would also consider using the Holley Terminator X Max system for engine and transmission control.
Andrew
I would consider the Summit 8715 "Ghost cam." It will outperform the ASA cam in every respect and have excellent manners. You will need a matching spring and pushrod upgrade.
Andrew
Andrew
The stock ASA GM tune leaves much to be desired and with a cam that has different characteristics will be even worse. With a mild cam, like the Ghost Cam, and the Holley Terminator X Max, I can tune it to better for you than a mismatched GM ECU tune.
The Holley also offers the benefits of a wide band O2 sensor, real time tuning, data logging, and flexible inputs and outputs. If you want an OEM type installation, AC integration, variable sped cooling fans, the Holley is the way to go.
Andrew
Andrew
G Atsma (07-27-2022)
LS1Tech Sponsor
Received 1,204 Likes
OP,
Great advice from the community. We wouldn't hesitate to put either the SUM-8720R1 or the SUM-8715R1 in this LS3. They'll make similar or more power to their comparable GM cam. The plus side is they'll be easier to get along with and be easier on the valvetrain. With either of these you can run our .600" lift beehives and they'll be happy. Some upgraded pushrods are going to be needed. You would likely end up with a 7.400" or 7.425" pushrod with either of the two cams. However, it's always best to measure first. We can help put a package together for you if you'd like. More info on the combo your putting together and the goals for it will help fine-tune a cam recommendation.
Let us know if we can be of any further assistance. We'll be happy to help!
The following 2 users liked this post by Summitracing:
G Atsma (07-27-2022), Project GatTagO (07-27-2022)
OP,
Andrew
G Atsma (07-28-2022)
The following 2 users liked this post by SLWRDE:
G Atsma (07-28-2022), Project GatTagO (07-31-2022)
