T56 magnum e36 driveshaft looks too long.
Is it at the extreme forward end of its travel? If "NO", it is too long.
And is it actually pushing against the tailshaft seal? If "YES", it is too long.
It’s seated exactly where it goes against the diff. It’s pushing against the dust seal not the seal that actually seals the fluid.
Sounds like a little too long. It should not push against any seal
How far forward can you still push it inside?
I actually think it is fine. The T56 Magnum has a dust boot, which is what the yoke is crushing a little bit. The actual seal is further inside.
Considering that this is a BMW with IRS, and the driveshaft isn't going to move forward or back hardly at all, I'd run it.
Andrew
Andrew
The following users liked this post:
G Atsma (08-21-2022)
Andrew
Andrew
Project GatTagO (08-25-2022)
Racer-X- (08-25-2022)
- The engine is mounted too far back.
- The bell housing is wrong (maybe from a truck?)
- The diff is wrong (too long on the pinion end) or mounted wrong
- If I put my mind to it, I could probably think of several other things.
And if there's no other way to gain clearance, I'd trim that dust seal instead of letting the thing shred itself until it has clearance.
G Atsma (08-25-2022)
Mm
From my ls e36 swap.., you may be able to shimmy the engine to the front a few mm w the tolerance of the mm to block and mm to frame.
as stated due to fixed mount irs there is no change in pinion angle w load.
gl
gl
