Factory '86 GMC cruise wiring for DBW PCM ??
Has anyone figured out how to use a factory mid-80's cruise stalk with a DBW PCM ? This is the logic for the switch.
This is what I am using now with a momentary up and down mini toggle and on-off switch.
You know that I use that on all my builds. Older switch, but that newer one is wired exactly the same. If you get the pigtail that the lever plugs into, which you will need if you ever want to be able to take the column out without cutting wires, there will be 4 wires on it, pink will be ignition 'hot', gray will be the 'on/off', green will be 'resume/accel' and blue will be 'set/coast'.
BTW, did you move? Never heard of Hog Back KS?
