Ly6 cam info
I'm looking to keep/gain as much bottom end torque so wondered if I'm better keeping the vvt?
also going to freshen up the engine before it goes in with new lifters, trays probably do the head gaskets with arp head studs and all other gasket & seals!
anything else recommended ?
im new to ls engines!!
and this will be DD
Thanks for any feedback.
I would probably go with this one: https://briantooleyracing.com/btr-ca...892538136.html
After more searching, I found this one on Summit:
COMP CAMS:
Manufacturer's Part Number: 156-402-13
Summit Racing Part Number: CCA-156-402-13
This COMP cam has -3 degrees of overlap. That would be better for daily driving. The BTR cam has +5.5 degrees of overlap. That's really not a lot of overlap, but it will be noticeable when it idles.
Your best bet is to call Summit, and ask which springs they recommend for these cams. They might even be able to find other VVT cams that will work better. This is just all that I found in the single bolt cams. I'm not sure if the 3-bolt cams could be used with VVT, but I doubt it. Either way, I would recommend trying to find something similar to the BTR truck cams. I wouldn't go bigger than a stage-2 truck cam for daily driving.
We like the range of cams that @Utinator and @68Formula are looking at. If you want to keep VVT and have good low-end torque take a look at the Comp Cams CCA-189-400-13. Specs on it are .556/.568, 210/224, 114+9 with -11* of overlap. With no retarding that would put the .050" IVC at 30* ABDC. This will create excellent throttle response and low-end torque with good power gains. Pair the cam with Comps CCA-26918CS-KIT beehive spring kit and it will be happy out to 6,300+. This cam will require Comps CCA-5460
cam phaser limiter kit.
We like the range of cams that @Utinator and @68Formula are looking at. If you want to keep VVT and have good low-end torque take a look at the Comp Cams CCA-156-400-13. Specs on it are .556/.568, 210/224, 114+9 with -11* of overlap. With no retarding that would put the .050" IVC at 30* ABDC. This will create excellent throttle response and low-end torque with good power gains. Pair the cam with Comps CCA-26918CS-KIT beehive spring kit and it will be happy out to 6,300+. This cam will require Comps CCA-5456 cam phaser limiter kit.
- 2007-08: The actuator has a 62* rotation. GM part number NAL-12585994.
- 2008-15: The actuator has a 52* rotation. GM part number NAL-12606358.
For reference check out our How to Delete VVT on an LS Engine article on our OnAllCylinders Blog. This has good info and images about VVT along with the ins and outs of deleting it.
We're all human here at The World's Speed Shop
