E38 help
Old Feb 27, 2023 | 10:31 AM
tom70's Avatar
Default E38 help
installing a 2009 6.0 in a 85 chevy k20. want to keep original turbo 400 transmission. I've been looking and I'm under the impression that I have to use an electronic transmission. If this is correct what are my options? I'm starting to modify harness for stand alone.
Old Feb 27, 2023 | 02:04 PM
aknovaman's Avatar
I suggest you keep your TH400, run a E38 ECU with a manual tans file in it. Done.
Old Feb 27, 2023 | 02:30 PM
tom70's Avatar
Thank you. Everyone was telling me I couldn't program with a manual transmission
Old Feb 27, 2023 | 06:52 PM
B52bombardier1's Avatar
The choice is typically to pick "non-electronic, manual" transmission or something like that when modifying your operating system tune.
Rick
Old Mar 2, 2023 | 10:07 PM
tom70's Avatar
I followed the information lt1 swap for stand alone harness What else can I eliminate from harness? I was thinking cylinder cut outs, oil pressure, fan and rear O2 sensors? Can I eliminate TECU since going with a tube 400? Or will I need TECU to be able to program the engine controller?
Old Mar 3, 2023 | 07:40 AM
aknovaman's Avatar
go here for a link to a zip spreadsheet file. it has the pinout for an E38 manual harness in one of the tabs.
[size=16px]https://ls1tech.com/forums/conversions-hybrids/1927203-mother-all-spreadsheets-tons-gm-pcm-pinouts.html[/size]
Old Mar 3, 2023 | 11:01 AM
tom70's Avatar
thank you! that's great. I'm deleting dod. can I get rid of those wires also?
Old Mar 3, 2023 | 11:29 AM
aknovaman's Avatar
yes be sure to turn off codes and set cam quality to zero is doing a cam swap.
Old Mar 3, 2023 | 06:37 PM
tom70's Avatar
Thank you very much for your help
Old Mar 3, 2023 | 08:00 PM
minytrker's Avatar
You need to flash it to a manual tune like manual camaro. You have to check the service number on ecm to see what year tune file to use. I recommend flashing it with GM software to change it to a camaro tune to make sure all 8 segments are correct.
