Suberado
Old Jun 16, 2023 | 11:26 AM
LQ4-E39's Avatar
Sweet swap. I thought for sure you'd be going turbo after you ran the one exhaust pipe around the front but it should still be a ton of fun.
Old Jun 16, 2023 | 11:59 AM
Bbknucks's Avatar
...maybe
Old Jul 6, 2023 | 07:07 PM
Bbknucks's Avatar
Gathered some bits and had the shop to myself for a long weekend with one goal...turbo time
Downpipe ingredients
Schedule 40 stainless elbow...stout chunk of metal
Tacked in with flange
Angle looks good...it was tough holding all this and turbo while trying to mark it to get alginment right
Turbo mounted...getting spicy
Turbo manifold with crossover modified from original layout
Hotside wrapped and coming together
Old Jul 6, 2023 | 07:10 PM
Bbknucks's Avatar
Wastegate in and heater outlets tapped and plugged
Downpipe constructed
A little heat treatment
Hotside complete
Now time for the coldside
Old Jul 6, 2023 | 07:16 PM
Bbknucks's Avatar
Dump pipe fitted
Old Jul 6, 2023 | 07:20 PM
Bbknucks's Avatar
Big ol cooler... gonna need some brackets and alot of cutting to fit
Was able to male the bumper beam fot with some slight modificating
All mounted and bumpered
Painted the bits
Old Jul 6, 2023 | 07:26 PM
Bbknucks's Avatar
Cold side constructed from a generic ebay 3in kit
Cutting aluminum was a nice break from the steel working
Almost looks like it was made for it
Old Jul 6, 2023 | 07:34 PM
Bbknucks's Avatar
Got the deka 80s in then swapped 3bar map sensor.
Moved fuel regulator from tank to engine bay for boost reference
Installed flex fuel sensor and wired to pcm
installed one way valve and any vacuum/boost reference lines
Flashed in the 3bar OS3with a fat and safe VE table
Weekend mission accomplished... turbo noises are sooo cool
Bumper on and ready for the 3bar tune and drive
Old Jul 6, 2023 | 07:36 PM
Bbknucks's Avatar
Little better pic of the finished bumper
Old Jul 6, 2023 | 08:55 PM
Bbknucks's Avatar
https://youtube.com/shorts/G4MdMMRF5qY?feature=share
Old Jul 6, 2023 | 10:09 PM
Bbknucks's Avatar
Old Jul 16, 2023 | 02:02 PM
  #32
Bbknucks's Avatar
With the turbo setup the Ram clutch I had in there couldn't hold. It was rated for 500hp but would just lose grip under boost above 60mph.
Picked up a twin disk setup from mcleod. Hopefully all will hold. Little more break in and we will hive her all the beans my fuel system can give her.
I was running out of fuel above 5krpm. I swapped the 340 pump with a 450 but still running lean up top. Need to verify fuel pressure but its gonna need more pump or injectors unless i limit boost at 10psi
Slapped my gauge on the windsheild and took it for a spin... definitely dropping pressure
Pulled drive train to separate engine and trans
Mcleod twin disk rated for 800hp so hopefully should be enough
Ram clutch was not having a good time
Got a little spicy
Walbro 450 crammed in the stock basket
Old Sep 4, 2023 | 04:52 PM
  #33
Bbknucks's Avatar
With a better boost controller she would really be putting it down
