69 Camaro 6.0 lq4
Old 05-07-2023 | 04:50 PM
frige's Avatar
Default 69 Camaro 6.0 lq4
This has been a slow project as well Im just slow lol. I have the engine sitting in the car. I used dirty dingo mounts and they seem to work well. This used to be a race car and still has the 4l80 trans. A standard flywheel bolts right up. I removed the midplate as I wont have that much hp and it will interfere with the exhaust.
So exhaust. I thought I scored a new set of hedman headers on marketplace. The guy said they were for a 69 camaro but ended up being for a 70 c 10. I paid to much for them but they are new maybe I will use them on a pickup. Note to self dont trust anyone on markerplace.
So now that I blew my tiny budget on the wrong headers what do yall recommend besides factory manifolds. Yuck.
Old 05-07-2023 | 07:38 PM
LS1 TJ's Avatar
I've used Speed Engineering headers on a couple LS swap projects. 68 C10 and a 80 Camaro. I know they are made in China. I just can't spend $1200 plus on a set of headers. They fit well and zero leaks.
The following users liked this post:
Jimbo1367 (05-08-2023)
Old 05-08-2023 | 06:32 AM
NCDEERE's Avatar
Second Speed Engineering, fit like a glove.
Old 05-08-2023 | 08:30 AM
frige's Avatar
Nice. I hate to admit but I paid more for the ones that didnt fit. You would think with old age comes more wisdom lol
Old 05-08-2023 | 11:46 AM
frige's Avatar
I went ahead and ordered the stainless long tube headers. Look good will see in a week.
Old 05-13-2023 | 09:31 AM
frige's Avatar
Got the headers in. They look good. Fit nice except for hitting the passenger side a arm. Its aftermarket so they probably would fit the stock a arms. I see a small dent in their future.
Old 05-13-2023 | 09:49 AM
Is it actually hitting the top arm mounting bolt? Shortening the bolt might be easier and look better....
Old 05-14-2023 | 04:49 PM
frige's Avatar
No its hitting the bearing housing. A small dent should do it. I hate to dent them but there is no other way.
G Atsma (05-14-2023)
Old 05-14-2023 | 04:54 PM
I doubt anyone would knock you for knocking your header... lol!
Old 05-14-2023 | 07:36 PM
91 Z28's Avatar
Can you just turn that bolt around??
Old 05-14-2023 | 08:04 PM
The pic doesn't look that way, but he said above that it's hitting the bushing, not the bolt. So he'll hafta dimple it, looks like....
Old 05-14-2023 | 08:53 PM
91 Z28's Avatar
Ah I see I see. A little dimple never hurt anything
Old 05-18-2023 | 02:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Looks nice. I've been running the DD motor mounts in my '67 Camaro for a while.
Old 06-07-2023 | 10:08 AM
frige's Avatar
I have the engine bolted in for good. I hope.
I am going to start collecting parts. I need a water pump I know its a dumb question but there are so many types out there. I will run a electric fan. Right now I am just going to have a alternator but later will probably have power steering and a/c. What would be a good unit to use?
Old 06-07-2023 | 11:06 AM
NCDEERE's Avatar
Look into ICT Billet brackets, the prices are hard to beat. They cover all of the different spacings from the engine.
Old 06-08-2023 | 10:26 AM
frige's Avatar
After doing some research Looks like I will have to have power steering and a/c. I was planing on it anyway. So First step will be a power steering box. I also bought a ac delco starter. Moving in the right direction. I need to win the lottery lol
Old 06-08-2023 | 10:05 PM
nleming's Avatar
Depending on how you are planning your layout the '11 Camaro water pump allows use of a (sometimes) cheaper SBC radiator because the outlet is on the opposite side. It uses truck accessory spacing which also is very common.
Quick Reply: 69 Camaro 6.0 lq4
