Silverado v6 to v8 swap
Old May 27, 2023 | 07:15 PM
gonejesus's Avatar
Default Silverado v6 to v8 swap
Swapped a 5.3 off a 2001 Tahoe into my 2007 classic Silverado originally 4.3 DBC , got the motor fully in mounted and all. I have the motor, it’s pcm, wiring harness and fusebox having trouble with the engine wiring, the underhood fuseblock c-2 blk connector from the 01 5.3 is not compatible with my original fuse box. Is there any way I can still wire in my engine? Does anyone have the diagram for the fuseblock i need. I saw a diagram out there but it’s different from mine. I’m thinking of finding both diagrams and repining the connectors. Should I go about doing this? Would it even work? My 5.3 also came with its fuse box but fuseblocks c1,c3,c4 are different from the 07 wiring aswell so I think I’d be easier to repin fuseblock c2 blk to get it working possibly?
Old Jul 5, 2023 | 04:34 PM
zachand799's Avatar
i’m currently doing a similar swap, 04 lm7 dbc intake into a 06 v6 2wd dbc truck. I have same problems for wire harness. did you ever figure it out?
Old Jul 5, 2023 | 04:50 PM
strutaeng's Avatar
The wiring changed from 99-02 to 03+ and are not interchangeable. You need to find an engine wiring harnesses and matching ECU that matches your truck, as close as possible.
I did an L59 from a 2004 suburban on my 1999 V6 Silverado and had the same issue. I wound up not using the 04 ECU and engine harness that came with the engine. Had to source a separate harness and ECU from a 2000 Silverado from the wrecking yard.
LT1 swap has ECU pinouts for various years ECUs. See if you can find one maybe 1 year +/- compare to see if there's any difference.
Edit: oops, meant to reply to OP...☺️
Old Jul 5, 2023 | 04:58 PM
zachand799's Avatar
I saw on performancetrucks you can use a express van 6.0 2wd 03+ and it’ll be dbc still but I havent been able to find anybody that’s done the swap themselves so I cant attest to whether it’s straight bolt or not. this is becoming a headache lol
Old Jul 5, 2023 | 06:06 PM
strutaeng's Avatar
Yes, that's supposed to be other option.
There's also a thread over there that shows how to open the ECU to see if it has the DBC driver. Some ECUs had them, even through they were DBW, but not all.
Are you set on DBC? I know everyone says they like DBC, but on my 06 Suburban DBW, I can't really tell the difference over my 99 DBC. At least not for daily driving it.
Old Jul 5, 2023 | 06:46 PM
zachand799's Avatar
i’ve been asking myself that question a lot because of the problems i’m having trying to keep it dbc but i’d just really really like it to be dbc if by this time next week I cant figure it out i’ll just have to surrender to electricity lol I love that cable ontop of the intake.
Old Jul 5, 2023 | 07:01 PM
strutaeng's Avatar
I thought the DBW change was due to the traction control feature on some trucks that had that option. The ECU is able to detect wheel slippage via speed/wheel sensors and controls engine throttle through the electric accelerator. Maybe in conjunction with the ABS module? I can't remember. You can't do that with DBC, that's why they switched.
I would say just do the easiest/fastest thing to get the thing running on the road again, then you can swap to whatever you want. I've never looked into making the gas pedal DBC to DBW, and if it's a reversible thing, so that may not be practical. I don't know for sure.
But getting a TAC module and electronic gas pedal should be pretty easy to swap in and off you go.
Old Jul 25, 2023 | 06:36 AM
zachand799's Avatar
so I got a 05 6.0 dbc 2wd wire harness and it does not hook to my fuse box. or to the other plugs under the fuse box that go to the truck. chassis is a 06 2wd dbc. do I need a 6.0 fuse box? i’m getting really really close to paying some body to figure this out for me, i’ve gone through 3 harnesses now, and two pcms and still have the wrong stuff. i’ve emailed the guru at lt1swap but i’ve never gotten an answer. if anybody wants some money come figure this out for me plz lol
