Nylon to steel fuel lines
Do you mean straight line or the GM quick connect style?
Summit Racing SUM-2200077B Summit Racing™ AN to Tube Adapter Fittings | Summit Racing
Earl's Performance 751166ERL Earl's Performance Vapor Guard OEM Quick-Connect Fuel Rail Adapter Fittings | Summit Racing
Something like this work? Put nut on steel line, flare it & use this fitting....?
https://www.summitracing.com/parts/d...IaAndCEALw_wcB
Best method is to flare the steel line for a GM quick connect. You need something like this set from Mastercool 71475. I bought mine a few years ago on eBay when someone had is mislabeled for a smoking deal.
The following 2 users liked this post by ryeguy2006a:
CattleAc (07-17-2023), Project GatTagO (07-17-2023)
Dorman makes a fitting to do it. Its a compression fitting on one side, a barbed fitting for nylon hose on the other side. I've used them and never had any problems with them. Its Dorman part number 800-035. Just Google it and it should come up
The following users liked this post:
rodstored-72 (07-25-2023)
I've personally never had good luck with compression fittings. I'd just find a buddy who has a Mastercool set that you can borrow, or have come over and use. It takes about 30 seconds to flare.
LS1, thanks for the replies I figure if it is good enough for you & works then it has got to be a reliable and working solution. ryeguy, I hear you... that tends to be my luck on comp fittings as well... sometime I get them to "Seal" and other times they just don't want to work for me...
