View Poll Results: Are you interested in swapping the ZF8HP transmission?
Yes, I am interested!
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
62
78.48%
I am unsure.
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
10
12.66%
I have no idea what you're talking about.
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
7
8.86%
Voters: 79. You may not vote on this poll
ZF8HP Transmission swap
#241
I have built several Maxxecu LS cars including a recent 72 Camaro build with an LS2, Ram 8HP70- all controlled by a Maxxecu Race. The Maxxecu 8HP control is very simple to configure and is an absolute blast to drive in this combination. PM me if you have any Maxxecu LS/8HP questions or need access to 8HP flash tool for Maxxecu setups.
Andrew
The following users liked this post:
Project GatTagO (07-16-2024)
#244
Yes, I've been a beta participant. The process is fairly simple. Wire the 8HP and a supported shifter (this car uses a Challenger shifter) to the Maxxecu CAN, and then source a Yanhua ADCP-2 flash tool to flash the 8HP with Maxxecu's custom firmware. Some dealers can rent the tool but not many US dealers have the tool available yet. I have a flash tool available to rent if someone can't access one through their dealer. In the Mtune software, there is minimal setup. A torque table, target RPM shift table, and miscellaneous drop-down options for shifter selection, transbrake operation, and driving mode. Shiftcut and throttle blip are optional but very easy to configure. Maxxecu has its entire MTune instructions on its website- including 8HP instructions.
Deude_Mann (07-16-2024)
The following 4 users liked this post by 02redchevy:
