View Poll Results: Are you interested in swapping the ZF8HP transmission?
Yes, I am interested!
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
62
78.48%
I am unsure.
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
10
12.66%
I have no idea what you're talking about.
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
7
8.86%
Voters: 79. You may not vote on this poll
ZF8HP Transmission swap
#61
Two of my customers have decided to go with the HTG controller. This will give me an opportunity to compare the HTG and the TurboLamik first hand, which is something that I would very much like to do.
Andrew
Andrew
The following 4 users liked this post by Project GatTagO:
#62
So do add to this discussion as I am now committed(sold the 4l80)
It looks like there are 3 main players in the controllers: HTG, Sound German Automotive, and Turbo Lamik.(There is CANTCU--however I don't know if this works with the Dodge version of these transmissions)
HTG and TurboLamik both require the modifications to the TCU as seen above(to me a little intimidating as from what I've seen the solder is hard to get to stick in some cases).
Sound German Automotive does not require the same modifications; however, it is limited on tuning if you're going to use it with Holley as it requires HP tuners to "tune" however it does come with an OBD port on the harness to do so and does require the use of a charger/challenger shifter.
I will likely go with the Sound German automotive set up myself.
The following 2 users liked this post by 02redchevy:
G Atsma (11-28-2023), Project GatTagO (11-28-2023)
The following users liked this post:
#64
If we are going to list all the options, there is also the HTG I/O CAN Gateway. It is similar to the Sound German Engineering solution in its mode of operation.
Andrew
02redchevy (11-29-2023)
#65
That was mentioned above.
Andrew
Andrew
Well I have another one to research. I have read a lot of negative about HTG(mostly on the facebook groups). Curious how that would work.
#67
#68
I agree, it's almost like the same people bash holley for being "junk" when it was their wiring that caused all the issues in the first place hahaha
Project GatTagO (11-29-2023)
#69
I known Sound German Automotive has an output for park/neutral safety if you so desire to hook it up. I would assume most have that output as well.
#70
#73
Project GatTagO (12-03-2023)
#75
Here is where I am with all of this. I have been trying to gather as much information as I can about both the TurboLamik and the HTG, especially how they integrate with Holley EFI. Sadly, there is precious little information out there. So either it is not being done very much, or people are being very secretive. If you do a google search for Holley and HTG or TurboLamik, there is barely anything out there. Seems Legit Garage claims that they have done "many" Holley EFI systems with the HTG, but even their El Camino uses a GM ECU. I also joined the HTG and TurboLamik FB groups, and while there seems to be quite a bit of interest in these swaps, there is very little actual information.
I am going to the PRI show this coming week and have a meeting on my schedule with the TurboLamik US rep. I also purchased a CAN course from HP Academy, which has been very helpful. That is all I have for now, but I will be making updates as more information becomes available.
Andrew
Andrew
02redchevy (12-03-2023)
#76
Andrew
Andrew
#78
That us true--that's only if I need to. It seems like SGA is continuing up update the computer as well. It seems like he's getting more and more features to work. I wish turbolamik was more reasonable on price(1600 for the comp, 400 I think for the harness, 650 for the shifter I want, and 150 for the pcb)
#79
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Andrew
The following 2 users liked this post by Project GatTagO:
DualQuadDave (02-12-2024), G Atsma (12-03-2023)
#80
The following 2 users liked this post by LSswap:
G Atsma (12-03-2023), Project GatTagO (12-03-2023)
