4L60E question
Old Feb 16, 2024 | 12:24 PM
Dscorp069's Avatar
Default 4L60E question
4l60e 2007 swap to 2009 4l60e electrically?
Old Feb 16, 2024 | 07:25 PM
mrvedit's Avatar
Moderator
First, I have no idea what you are asking.
Please explain in much more detail. I should then be able to answer any 4L60E compatibility or conversion question. I may move it to the Automatic Transmission section.
Old Feb 16, 2024 | 07:49 PM
the_merv's Avatar
Veteran: Air Force
I know what he's asking.
2008-up 4L60E is different from the 07-back, different electronics. So no a 2007 unit will not work in plce of a 2009 unit.
Wouldn't hurt to move it to the Auto Trans section since this is specific to that.
Here's a thread that may have some info..
https://ls1tech.com/forums/pcm-diagn...cs-2008-a.html
Old Feb 17, 2024 | 08:08 PM
mrvedit's Avatar
Moderator
Actually its the 2009+ 4L60E/4L70E which is completely different electrically from earlier years. Post #6 in the following thread details how even all the connector pins changed in 2009: https://ls1tech.com/forums/automatic...e-pin-out.html
Of course that doesn't @the_merv conclusion that a 2007 and 2009 are not interchangeable.
However, I was wondering if maybe the OP wanted to modify a 2009 to be 2007 compatible or vise-versa. (Yes it can be done by swapping valve bodies, harness and a few other parts.)
I'm going to leave this thread here, because this is "well known" in the Automatic Transmission section.
