Ls1 bracket questions
Old Mar 14, 2024 | 03:03 PM
mapmatt08's Avatar
Question Ls1 bracket questions
Have a 99 tahoe that i put a ls1 in. still trying to find more parts to make this thing run. i have been through a few things all to a dead end as to why i am here. the motor came from either a 98 or 99 camaro, it was in a 59 vette for little over a yr. when it was pulled the alternator and bracket where kept and no power steering with that car. so this is what i have been trying to locate without success. the alternator bracket and alternator, power steering pump (lines if they are compatiable) and bracket, the ac conversation to work with the lt1 ac compressor from the tahoe. i talked with summit racing and several people about these items, learned a lot but not enough. 1st time motor swap (i realize a different motor would have been easier but here we are) i am also unsure about a plug and play wiring harness as some are 1200$ online and just today a guy who does this for a living said i could find one for 200$ (he doesnt want to work on what i already started, understandable, but that leaves me back at square one) any info links or knowledge would be greatly appreciated. Central AL
Old Mar 14, 2024 | 06:26 PM
mrvedit's Avatar
Moderator
Many people like the inexpensive brackets from DirtyDingo:
https://www.dirtydingo.com/shop/index.php
Ask them about compatibility with your desired AC compressor.
If you like that, ask them which PS pump they recommend. I have used an early version of their bracket and it wasn't fully compatible with the PS pump I bought.
For several LS swaps, I bought the main engine harness on ebay for around $200 and received excellent quality.
Since it sounds like you are buying a harness, I would recommend one for a 1999-2002 and then buying a "411" PCM, even if your motor came with a '98 PCM. (The '98 PCM is wired differently from the "411" for '99 through 2004 or so).
Old Mar 14, 2024 | 08:24 PM
Mixednuttz's Avatar
Are you trying to use the factory compressor for the truck like this one? (Don't mind the terrible looking engine bay. This truck is my winter beater.)
This is a 99 Suburban. I used ICT Billet brackets. They make a setup that uses the factory compressor and power steering pump from the late (Vortec) GMT400s. Factory AC lines work, just had to bend one side a little to clear the intake cover. I used a different alternator and bracket (from them) to allow clearance for the turbo. I believe the other alternator bracket locates it pretty much where the stock GMT one sits.
Old Mar 14, 2024 | 08:50 PM
33willys's Avatar
If you are looking for a Dirty Dingo low mount a/C bracket (for sanden) I have a new set in the box for $135.
Old Mar 15, 2024 | 10:17 AM
mapmatt08's Avatar
thanks a ton for the info and the link i will be investigating this afternoon with all the info.
Old Mar 15, 2024 | 10:20 AM
mapmatt08's Avatar
dang that turbo is a nice idea, for now just trying to get this thing going down the road. yes the factor comp will look into all you wrote, thx for the info!
Old Mar 15, 2024 | 10:22 AM
mapmatt08's Avatar
not looking for a low mount bracket but thx
Old Mar 15, 2024 | 10:37 AM
jmilz28's Avatar
Try ICT Billet, they will have what you need.
