Ls swap neutral safety switch
New to the site and was hoping someone would be able to help me out.
I’m almost done my ls swap project (5.3L paired with the 4 speed automatic 4l60e) but wanted to see if someone could help me with a detail I am unsure about. I have the terminator x max (Part # 550-917) with trans control. I am wanting to use an American Shifter transmission mounted shift kit that had two prongs for a neutral safety switch on the side of the shift kit. I’m wondering when it comes to the neutral safety switch, would I have to wire in the factory neutral safety switch with the transmission or would I be able to just wire the neutral safety switch on the aftermarket American Shifter transmission mounted shifter?
Any help would be great.
thank you.
Linkage (without factory neutral safety switch)
The project
My transmission mount shifter
Often the shifter has its own switches, one for the Reverse lights and one to provide a closed circuit when in Park or Neutral. This is my personal setup; there is no OEM switch.
Hopefully that helps you make your own decision; personally if your shifter has those switches, I would use them. For one it reduces the wiring under the car which can get wet and damaged.
The Lokar shifter only has one switch and that's the NSS. When the shifter is in park and neutral the switch is "closed" allowing 12 volts to the starter. Any other position like drive or reverse the switch is "open" not allowing 12 volts to the starter. Make sure to check it with a meter to confirm 12 volts in park and neutral only when you get the shifter rod adjusted.
I've never used that switch for back up lights. I don't care if I have back up lights.
If you decide to use the GM switch on the trans shift shaft make sure you run all 12 volt output thru a relay. The trans shaft switch is not designed for high amps or volts.
No need for a relay to operate the signal wire for the starter relay wire. Nor am I running a relay for the reverse lights and I don't believe the OEMs did either.
Now, I don't know whether your PCM has been reprogrammed to only need a one wire range signal or not, so I don't if that will create issues. I'm only working off of the instructions that are here, and I too am working with the OE single plug PNP/NSS.
Since the OP has a much older vehicle, I suggested keeping the wiring in the car and using the shifter switches.
ALSO - as a long time contributor/moderator in the Automatic Transmission section, I wanted to dispel the frequent belief that this switch is needed to make the transmission work properly. It is not, many swaps with 4L60E/4L80E skip the Park/Neutral safety switch. The PCM/ECM knows the position of the shifter through the main wiring harness going to the trans.
I do like @the_merv 's suggestion of running the ground for the starter relay through the shifter, instead of the starter circuit from the key. With the moving parts of the shifter, it is easy for a "hot" wire to get shorted.
In older cars the key's starter circuit often went directly to the starter solenoid (Fords were a bit different). Most modern cars use a starter relay. In Camaro/Firebird/Vette it is located in the main fuse/relay box.
See also: https://ls1tech.com/forums/general-m...-location.html
I do like Ground triggers as well and configure that way when I can
which leads me to a quick but related hijack question.
I’m sending 12v thru my switch on my B&M shifter to the starter noid. Is that a problem? I didn’t think there was a big draw here and figured the switch could handle it.
The side says its rated at 16 Amps for AC power but only 0.1 Amps for DC power, which makes no sense at all.
The following thread on another site discusses the issue of running the starter solenoid power through this microswitch; a bunch of people say they have been doing it for years without problems.
FYI, a Google search indicates that a typical starter solenoid takes 8-10 Amps when energized, which agrees with the relatively large OEM wiring to the solenoid.
Also, since you usually shift into Park and then hit the starter, and not the other way around, the switch isn't getting much electrical abuse.
