Fuel Pump / Starter - ECM control or direct wire??
Thanks for any advise!!
Cheers TM
The prime feature is the only benefit
If your pump does NOT have a built in check valve, it can be worthwhile to run continuously
Personally, I always use ECM control for the pump
Starter is always external. Typically, OEM starter relays are a part of the anti-theft system
Thanks all for the input!!!!
Cheers TM
Since the OP did not state which controller he is using, we can only speak in general practice
Its the stock unit from a 2005 Savanna 3500 with a 6.0ltr
