Fuel Line sizing at pump/sending unit..5.3L LM7 w/cam &headers
Hey guys,
Tried finding some info on this but no luck. 1990 Jeep Grand Wagoneer swap. Putting a 5.3L LM7 with a truck norris cam and headers. Nothing crazy for this thing. I ordered an efi conversion pump sending unit for the factory gas tank and they (novak) told me over the phone that it had 3/8" on supply side and 5/16" for the return (thinking great i did this on my ls3 79 vette swap, it'll work fine).
Got the sending unit in today and its the factory GW size of 5/16" supply and 1/4" for return. Are those sizes sufficient for this setup or should I return it and go a different route for this LS setup?
I'm routing -6an from pump to typical filter/regulator close to tank, then -6an supply up to fuel rails and -6an return back to sending unit.
thanks for any advice.
Ryan
Ryan
Hey guys,
Ryan
Ryan
I agree the 5/16" and 1/4" is too small.
Just a question? Does the Novak tank include the fuel pump (like a Walbro 255) along with the fuel level sensor? Any pics?
When I built my TJ I used the stock tank but I made the mount for the fuel pump/level sender and the -6 SS fuel lines. Kind of hard to explain but the TJ tank opening for the fuel pump has a big plastic nut that kind of looks like a big fruit jar nut holding a round plate in place. I made a new round metal plate that I mounted the fuel pump/sender and then using -6 o-ring fittings for the output and return. Then a C5 FFR.
Mixed responses. I've done 3/8 with -06an on a ls3 with a cam and no issues. Maybe I expected too much of them for $300 even after confirming sizes over phone and receiving something different.
Thanks for the advice..
on a different note, many say that the factory GW plastic tank is not great for EFI due to the lack of baffling. you could probably get around this by keeping the tank at least 1/2 full. its my understanding that many use a tank from i think a 1997 2 door blazer? and it fits behind the rear axle where the spare would normally be. the 97 blazer tank is already set up for EFI. hope that helps
