I need help!! Ground short
Old Oct 1, 2025 | 10:51 AM
Boybadone's Avatar
Default I need help!! Ground short
I need a favor from the gurus!!
I am having a tough time tracking down what I think is a ground short.
I am currently testing the connector on my 4.8 for the coil packs. When I check continuity between the negative and positive terminals I get 1.653k ohms. Should I have any continuity there?
Old Oct 1, 2025 | 08:27 PM
ls1nova71's Avatar
If you have the coils plugged in, you're going to have some continuity. If you suspect a short in the harness, which is doubtful since its such a small harness and taped up well, unplug all the coils first, then test it. Anything is possible I suppose.
Old Oct 2, 2025 | 12:42 PM
Full Power's Avatar
What does the coil pack on the OTHER side of the engine read?
They can't BOTH be bad.
Old Oct 2, 2025 | 12:53 PM
ss1129's Avatar
Disconnect the coils and disconnect the harness from the PCM, then ohm the harness. Also, what issue are you having?
Old Oct 8, 2025 | 12:47 PM
Boybadone's Avatar
Sorry guys, I am still trying to figure out this site. I think I need to subscribe to this thread or check it more often.
it turns out, I do not have a short. The coils were reading correctly.
However, the real issue I’m having is rough drivability, and a hesitation upon acceleration. I have been fighting PO135 and PO155 codes since I purchased this thing (heater circuit in the O2 sensors.
I checked, and I have both 12v with the key on and ground at the plug. I replaced both oxygen sensors with brand new Bosch units. I checked the pin out from the connectors to the PCM. The census are definitely reading because I can see it in my scan tool. Although the values are a little high. ( i think they want to be around .450v)
I have no idea how to continue diagnosing.
Old Oct 8, 2025 | 12:48 PM
Boybadone's Avatar
I have the 4 wire isolated ground connectors. My computer is a P59 with green and blue connectors.
Old Oct 8, 2025 | 03:26 PM
Boybadone's Avatar
For reference, this is a 1988 Jeep Wrangler YJ with a 4.8 Vortech and 4L60e swap. It has a Chinese harness.
Old Oct 9, 2025 | 10:05 AM
Pocket's Avatar
I've had terrible luck with the chinese harnesses at my shop. Usually the cost to troubleshoot them exceeds the cost of a quality harness
That said, your issue doesn't see to be in the coils but instead, oxygen sensors, specifically the heater circuits
There were two types of HO2s used over that generation of PCM and mixing them up will cause issues. There's a good explanation of the differences in here
https://lt1swap.com/vortec_o2_sensors.htm
Use your meter to ohm out the harness connectors to see which it's wired for
You need to match harness type, HO2 type and PCM base file. Harness will be the hardest to adjust for, so swap the sensors and/or tune
 Michael S. Palmer
Old Oct 9, 2025 | 10:21 AM
Originally Posted by Boybadone
For reference, it has a Chinese harness.
Here's your issue.....
Old Oct 9, 2025 | 02:03 PM
Boybadone's Avatar
Thanks for the help guys. I agree the Chinese harnesses are junk. If I ever build my own, I will use a quality harness. Unfortunately, for now, I am stuck with what I have.
It looks like I have isolated ground oxygen sensors. I confirmed with the guy I purchased my flashed computer from. I have a tune for a 2004 Silverado 1500 with a 4.8.
originally, I purchased these o2 sensors. But then I realized I needed female plugs connectors, not male.
Amazon Amazon
so I purchased these because they have female connectors. That is what I have installed currently.
Amazon Amazon
after taking with the guy that flashed my computer, he thinks I need upstream sensors from a 2004 corvette. So I guess I will be getting these next. Fingers crossed, they solve my issue.
Amazon Amazon
Old Oct 9, 2025 | 07:30 PM
Pocket's Avatar
You're never stuck with something
If it's yours, you can nix any part at any time
If it's a customer build you can tell them it'll be more to troubleshoot than it's worth. They can pay for a proper part or pay you to fix the junk parts
Also, you're starting at the wrong point
The harness is the hard part to change, so identify which HO2 style it's built for
It doesn't matter which sensor or tune you have right now because one/both of them are incorrect
Old Oct 10, 2025 | 09:04 AM
Boybadone's Avatar
Pocket,
how do you recommend I proceed? Should I not try the Ho2s for a 2004 corvette? That has the same plug that I need?
if a sensor has the same plug and four wires, does it always have a heater circuit? Are the resistance values similar in all of these Ho2s with 4 wires?
all I have to go off are the sensor connectors
Old Oct 10, 2025 | 10:06 AM
Pocket's Avatar
You need to identify how the harness have the O2s wired. To do that, you need to ohm out the O2 connectors against each other and to the PCM pins
EX: case on the left, isolated on the right
https://lt1swap.com/01_6.0_case&isolated.gif
With the PCM unplugged (D/C your battery first) ohm the tan wires on the harness (pin A). Are they connected or not? O/L means case grd, 0-10 ohms isolated grd because they're placed together somewhere in the harness. Confirm the sensor connector to PCM pins are connected properly
Next, test the heater + circuit (pin D). Does it go to fused IGN 12v at a fuseblock (case) or to a PCM pin? (Isolated) This will relate to the trouble codes listed above
Since you're there, I'd recommend testing the high signal to PCM (pin B) and heater grds (pin C to batt -)
Once you've identified which type of sensor you need, confirm whether your existing sensors are case or isolated then move to the PCM file
Old Oct 12, 2025 | 04:18 PM
Boybadone's Avatar
Thanks, Pocket.
unfortunately, I am a newbie when it comes to wiring so I didn’t understand everything that you described.
I know I have 12v to the heater circuit from my fuse block on a 25amp fuse. I have ground (low reference) as well. All pins at the HO2s connectors have continuity with the corresponding pins on the ECU side for a P59 computer.
Other than a high reading, the ho2s seem to be responding but their values are high. It just doesn’t seem that the heater circuits are working.
Old Oct 13, 2025 | 10:50 AM
Boybadone's Avatar
Here is what I found connected to each pin for the H02S connectors:
Bank 1
Pin A: pin 29 at ECU
Pin B: pin 69 at ECU
Pin C: pin 72 at ECU
Pin D: 25 amp fuse
Bank 2
Pin A: pin 26 at ECU
Pin B: pin 66 at ECU
Pin C: pin 74 at ECU
Pin D: 25 amp fuse
Old Oct 16, 2025 | 05:35 PM
Boybadone's Avatar
I traced the ignition back to this fuse block on my Chinese harness
