Need help!
To answer your questions here, first decide which ECM you plan to use. If an OEM style ECM like the older 0411 box, be sure to find a tuner willing to take it on. LS tuners are becoming less common as days go by. OEM style boxes are very restrictive on what parts can be mixed/matched, esp with DBW. Aftermarket systems like holley terminator are much more flexible to which components you need and can use
Cost will follow which route you choose, but don't let the number dictate the path or the build will become more difficult/costly in other areas
