87 RX7 Update
Old Aug 9, 2004 | 09:02 AM
Project GatTagO's Avatar
Default 87 RX7 Update
Just wanted to give you guys a little update. I got the car running in time to take it to the Chicago Super Chevy Show. You should have seen the looks on peoples faces. I was there only on Friday and was able to make 4 passes. All the runs were made on Sumimoto 205/55/16 radial tires. The track scales read 3175 with my 250 pound *** driving. I discovered that I have no 5th or 6th gears, so I was going through the traps in 4th gear banging against the rev limiter. The best pass of the day was 12.30@115mph with a 2.031 60 foot time.
Andrew
Old Aug 9, 2004 | 07:18 PM
John B's Avatar
Moderator
Very nice! And by the way, you want to gear your car to go through the traps in 4th!
Old Aug 9, 2004 | 08:03 PM
Payne's Avatar
Unfortunately, they dont make higher gears for RX7 diffs
rotaries need to spin it up above 6000 to make power, so 3.9s are the highest you can get in a RX.
Ill be shifting into 5th as well to get 120 mph traps.
Andrew, good shakedown times (well mph at least) Cant wait to have mine on the road.
-Jason
Old Aug 9, 2004 | 08:30 PM
NOSjohn's Avatar
Restricted User
Super sweet, sounds like the exhaust is choking it in the vid.? Is the motor all stock and does it still have the stock 2" exhuast? GREAT RIDE !!
Old Aug 23, 2004 | 08:01 AM
simplecat's Avatar
-Jason
I'm pretty sure they made a 3.73 in the auto na's, but you can check for sure over at rx7club, they'd know offhand.
GREG
Old Aug 23, 2004 | 08:05 AM
simplecat's Avatar
-Jason
I'm pretty sure they made a 3.73 in a certain model, maybe a na auto? they'd know off hand over at rx7club.com
GREG
Old Aug 23, 2004 | 05:29 PM
Payne's Avatar
GREG
Thats in the FCs, I am building a FD, which has a different IRS. All were twin turbos. Autos have 3.90s and manuals have 4.10s
-Jason
Old Aug 25, 2004 | 01:20 PM
gnx7's Avatar
Andrew-
You are hauling some butt!!
The only gears offered for FC's and FD's were 3:90's and 4:10's from the factory. Next option is to go deeper gears which is in the wrong direction.
Rotaries need torque multiplication so most put in crazy 4:30+ etc gears...
-GNX7
