throttle cable, 3rd gen
Old Sep 30, 2004 | 04:13 PM
Josh Kersten's Avatar
Default throttle cable, 3rd gen
I'm working on a 92' Camaro Rs with a LS1/M6 in it. I'm trying to find the right throttle cable to fit LS1 throttle body and 3rd gen firewall cutout. My stock 3rd gen cable is too short and had the wrong end to it. Summit Racing has a uniersal throttle cable, but don't know if it will fit right. Any help would be great thanks. Josh Kersten
Old Sep 30, 2004 | 07:21 PM
crainholio's Avatar
I used the Lokar LS1 universal cable, but it needed some modification.
First, I had to add a pair of large stainless-steel fender washers and rubber washers at the firewall...the Lokar cable is smaller than the 3rd gen cable hole.
Second, I cut the clevis attachment off the throttle pedal end of the Lokar cable and put a bullet end in it's place. This allowed it to seat in the little plastic cup exactly like the factory 3rd gen cable.
Old Sep 30, 2004 | 08:06 PM
92CamaroReallySlow's Avatar
Yea I did the same thing, but i still have the clevis attachment.
Crainholio: How did you attach the cable to the throttle body? I know how the stock ones go, but I cant figure out how to attach it with out ghettoriggin.
Old Oct 1, 2004 | 06:48 AM
crainholio's Avatar
The TB end went on without modification. Hard to describe, other than the barrel-end on the cable goes into the slot and the cable wraps around the tb arm in the little groove designed for it...just like the stock cable.
Old Oct 1, 2004 | 06:50 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
I use the stock throttle cable from an LS1 4th gen. Although the firewall hole isn't an exact match to the 4th gen cable, it pops into place and works just fine.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Oct 1, 2004 | 02:17 PM
Crainholio: yea i know that the cable goes down the groove, but I cant see how to attach that barrel-end to the throttle body correctly. What I did was thread the cable through the little opening on the passenger side of the arm. Ghettorigged, but works if i need it to...just want to try to get it like it should be. If i can Ill get a pic tonight
Old Oct 2, 2004 | 09:23 PM
Brads454's Avatar
What he said...I had to bend the pedal arm some to get WOT, but it works well and looks stock.
Old Oct 4, 2004 | 03:52 PM
Thanks, I will go pick up one this week. As long as it doesn't pop out of the firewall hole, but I can modify it some if I have to. I still have to put exhaust on too. I'm wondering if I will have trouble with my o2 sensor readings. I was able to put 3 sensors on, but the one on the driver side off the exhaust manifold wouldn't fit.
Old Oct 4, 2004 | 03:55 PM
Thanks. I'm going to pick up the stock fourth gen cable and if that doesn't work than I'll use the universal one. I'll let you know how it turns out. Thanks for your help. josh
