4L60E question.....?
Old Oct 20, 2004 | 06:58 PM
jlm44's Avatar
Default 4L60E question.....?
I can pick up a ls1 and 4l60e combo for a fair price but me question is with this transmission am I force to run the shifter on the floor or can I switch it over to a column shifter? Or should I buy the ls1 by its self and then pick up a 4l60e or 4l80e out of a truck do to the fact that the shifter is on the column.
Old Oct 21, 2004 | 02:18 AM
jlm44's Avatar
anyone?
Old Oct 21, 2004 | 11:42 AM
onehardmaro's Avatar
Im sure you could just use the shifter from the truck if you would like. I wouldnt be surprised if it was an exact fit.
Old Oct 21, 2004 | 11:43 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
You can simply remove the cable actuator arm from the trans and replace it with a column shifter arm from a truck. Just one nut holding it on.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Oct 21, 2004 | 06:56 PM
jlm44's Avatar
Thank you fellas!
