Mechanical speedo
Old Nov 1, 2004 | 07:16 AM
dsrour's Avatar
Default Mechanical speedo
Does anyone know anyone who converts a T56 trans to mechanical speedo output? thanks
Old Nov 1, 2004 | 08:33 AM
Scooter70's Avatar
If you're going to put it behind an LS1, the PCM needs the VSS signal to function properly. So some searching on VSS to find a few threads that talk about why the computer needs to know if you're moving.
If this isn't the case, D&D Performance (http://www.ddperformance.com/) might be a good place to start. I don't know where you are, but they're local to me in the Detroit area.
-Matt
Old Nov 1, 2004 | 02:46 PM
LS69TA's Avatar
I have been wondering the same thing..
Old Nov 3, 2004 | 07:35 AM
Kevin Winstead's Avatar
Another alternative is to use one of our Speedometer Control Units (SCU). The part number is 377300. It translates the electrical signal into a mechanical output. You'll also need a cable. Part number 377301 fits the '71 and older threaded style speedo. Part number 377302 fits the later model clip on speedo.
Kevin Winstead
TCI Automotive
(662)224-8972
Old Nov 3, 2004 | 11:30 AM
Mark IXZD 150's Avatar
I'm using an Abbott Cable-X converter box which takes the VSS signal from the trans and converts it to a mechanical cable drive. Haven't installed it yet but have heard positive feedback about it.
Old Nov 4, 2004 | 08:43 PM
John B's Avatar
Moderator
Ditto. Works great for me!
Old Nov 4, 2004 | 09:22 PM
Scooter70's Avatar
Kevin,
What is the cost of your unit? I have no speedo in my car because I couldn't justify the cost of the Cable-X. I'm sure there are people out there looking for a lower-cost solution.
Thanks,
Matt
Old Nov 5, 2004 | 07:16 AM
dsrour's Avatar
There is a company www.stealthconversions.com who converts T56 tail housing to mechanical and VSS. They have the conversion for LT1, but not LS1. Would there be any differences w/ the signal?
Old Nov 5, 2004 | 11:55 AM
Hi Matt,
The price directly from us is $400. I'm sure you could save a few dollars by going through one of the LS1Tech Sponsors.
Kevin
Old Nov 5, 2004 | 01:25 PM
In my case the Cable-X was the cheaper option. At the time, a modified tailshaft cost more. The other factor is that I wanted an Autometer 200mph speedo with a standard odometer and it was only available as a mechanical gauge.
Old Nov 12, 2004 | 01:38 PM
RFERG43's Avatar
Default Speedometer
I'm in the planning stage right now but as soon as my conversion is complete I plan on making my own electrical to mechanical converter using a few ICs and a stepper motor. Shouldn't cost more than twenty bucs. When I get it made and tested I'll post a schematic.
