2nd Gen Fuel Tank Questions
Getting ready to go get the parts set up for the LS1 swap. I have talked to a few companies about getting a new tank made, but they want near 1K for a new tank with the pump and everything. BRP Hotrods makes a kit that screws up to the tank with AN fittings, and goes through the stock corvette 45PSI regulator, and then you put an aeromotive inline pump. Those parts will be roughly 500 bucks, big savings. What have you all done for the tank end of your swap.
John
John
I'm still trying to get my 79Z running (a TBI retrofit that's been over 2 years and counting so far). For now, I'm just running the stock pickup, an MSD fuel pump mounted low on the driver's side frame rail, -6AN braided lines for both supply and return, and I put a 3/8" tube in to the stock sending unit in place of the small 1/4" tube for return. I have had problems with too much pressure at the throttle body (70 psi is no good for a ~17 psi system). I know that this won't work well with the tank less than 1/4 full, but I just want to get the stupid thing running. It was only supposed to take a few months...
Keep in mind that with the LS1, you want 60 psi of fuel pressure, not 45.
I also have a 79 Camaro that I’m putting a ls1 in. I’m just using the sock tank with a 1/2-inch fuel sump that go's to a -10, in to aero motive fuel filter to an a1000. I’m running -10 to the aero motive Y block; from the Y block I have -8 to a set of VERY nice fast fuel rails. After the fuel rails it has -8 to a aero motive fuel regulator and from the regulator back to the tank I’m using -8. It looks really good and it should be more than enough for heads cam and a little juice. So hope it helps so far I have about seven hundred in the fuel system but if your going to retro it you might as well do it right .
Restricted User
used 2nd gen tank & 99 pump
I put 99 cam. pump with sending unit into stock tank.
had to weld adt. brk. to top of tank.I also used the 99
lines & filter. I had whole wrecked car.
