LS1 into a 95 v6 camaro
not a hard swap,took 2 days
Originally Posted by 95vslowcamaro
alright, I got an LS1 out of a car a friend of mine had wrecked and was gonna send to a junk yard. me and another friend have decided since that engine is in pretty much perfect shape (the rear end of the car was smashed pretty bad, but the front end was left undamaged), we decided we are gonna put it in my car aka 95 v6 camaro. we have debated what is going to need to be swapped out or replaced. basically i was wondering if anyone on here has done a swap like the one we are gonna do, and if anyone could tell me some of the parts we are gonna have to be swapping out (not including suspension or drivetrain)
nothing too it, it took me 2 days to do the swap,with no painless wiring kit, had to do it the hard way, it will fit under the hood ,and you dont need any parts, why buy a fuel rail that the motor doesnt need, the return is for your car not the motor, just plug it. the throttle linkage will work it just needs to be fliped upside down. and on the swap just unhook all hoses and wiring and 6 large bolts on sub frame and start dropping the motor slowly, look for any wires still attached, then slap the entire sub and motor back in. if no painless kit get a detailed wiring diagram,to cross reference computer to the car. the only piece i needed was the key bypass for the anti theft to start the car. it was 170$ for one so, i made one . any ?s let me know,ive been there its not that bad.
you will need the key bypass, the computer will not let the car start unless it see's a signal from a matching key chip,if you cant make one go to your nearby hot rod shop,they should have one. oh yea remember ls1,returnless fuel system ,no return,save your money and cap off the third line!!!!
the engine was out of a 98 ram air,and if you pay attention to every aspect you can hook up the data port also, that really comes in handy for tuning.it was a 6 cylinder, but as mentioned in a earlier post, try to use the ls1 sub it makes mounting a breeze. as far as fuel pressure goes, i swapped tanks with the ram air so it gives you the right pressure,i also straight wired the pump so it doesnt sense pressure and cut back,giving you a constant flow,and have never had any issues with the car,exept the fuel guage hook up took a little work. but i did get a cluster out of a 97 v8 and it was a simple stick and go deal.but since i got off the subject,fuel pressure runs high because of the straight wired pump, but can you ever get enough fuel? im new to this site,so i need to get you guys a pic of my car i know you will love it,she is a beauty
mods___98ls1 into 96v6, hooker lt's ,granetelli maf ,iat, coolant bypass, diablo,lg throttle body, lunati cam ,springs,lifters,3600 stall,3.73 gear,wot sensor, timing tricker,loudmouth w y
stylish looks include: factory medium quazar blue metallic paint, ground effects, wing, ram air hood, 20 inch wheels, tint
oh on the fuel guage try grounding the tank to the car with wire or a strap,guage should drop from really full to correct fuel level
I did that exact swap.
I swapped everything over. All the wiring from the ls1 car, the ls1 dashboard, ls1 gas tank and fuel lines, ls1 suspension and brake parts. Hood won't close with the ls1 intake btw.
Took me a couple months but I only had a few days a week to work on it.
Originally Posted by JVs95LS1Z28
those 97 vette fuel railes are expensive. The Cheapest I ever found one was for like $500. I got my tank and fuel lines for like $300. It's probably easier to modify the wiring from the tank and call it a day. My .02
im working on my 96 t/a 98 ls1 right now, ive got the speartech conversion harness, 97 c5 rail/regulator. moroso lt1 intake, stock 96 interior wires, stock 96 tank, ls1 k-member, a-arms, front brakes.
pics soon.
pics soon.
#33
yeah my biggest prob on the swap was intake,anyone know if the k&n fipk oval filter will work?
goodluck
#35
I just turned a 94 V6 Camaro into a road race/auto-x car with the LS1/T56 from my old 1999 SS.
Pictures:
http://bervickbradstreetracing.com/cricket94/gallery/
The intake I fabbed up cost around $35. Sewer coupling and vent pipe from Home Depot!
If you are sticking with the manual transmission, you need an LT1 T56 crossmember, the LS1 style crossmember WILL NOT work.
That an there are about a hundred other odd things that didn't end up right, including the clutch pedal.
Long story short, if you don't have a donor car sitting next to it, you will need to buy a lot of random parts.
Post up any questions you might have.
Pictures:
