LS1 into a 95 v6 camaro
No changes to the suspension or drivetrain that I can think of, except different rates on the springs, but that isn't necessary, in fact many races change out the v8 springs for v6 springs.
Transmission is probably the only thing that needs changed in the drivetrain.
like camaro_slp, the shell and fuel tank is the only thing thats orignal in my 94 camaro. i sold/traded my front end parts and did a front end conversion as well. take your time, do some reading, have all the parts ready and you'll be alright. good luck!
my fuel level indicator is still off so i'm trying to find a good deal on a tank/pump assembly and i'll just modify my fuel lines.
if you can wait i might be selling my 97 vette rail with regulator soon.
You don't have to change anything in the engine bay or wheel wells.
. i have the engine, intake, wires, radiator, driveshaft, rearend, k member, control arms, tourqe arm, throttle body, springs, transmission mount,fuel lines, plugs and lower control arms. That i know of i need a trany, computer, wiring harnest. would i need to swap out my gas tank? (i have the ls-1 fuel lines) Since my rs came with the y87 proformance package (posi, and same suspension as a lt-1 z-28) that should cover my rear end shouldnt it? if you guys can think of anything else i would need, any feed back would be apriciated.
strangeater01 --- what year car is the ls1 going into and what year is the ls1?
