Chevy 2 headers
Old Feb 4, 2005 | 07:14 PM
MADMAN's Avatar
LS1Tech Sponsor
Default Chevy 2 headers
We finally finished the headers on our 66 Chevy 2 with the LS1. They are 1 3/4 longtubes with 3" collectors. They can be installed with the motor bolted in . The only thing you have to remove is the starter. Now as you know these headers fit the stock frame and front suspension They will be included in our install kit.
Pics will be up this weekend.
__________________
www.madmanandcoracing.com
225-343-9029
Old Feb 5, 2005 | 12:46 AM
BBPanel's Avatar
Veteran: Marine Corps
Look forward to seeing them - how long are the primaries? What gauge material, flange thickness, etc. Will they be sold separate from the kit and what will pricing be like? -Bob
Originally Posted by MADMAN
We finally finished the headers on our 66 Chevy 2 with the LS1. They are 1 3/4 longtubes with 3" collectors. They can be installed with the motor bolted in . The only thing you have to remove is the starter. Now as you know these headers fit the stock frame and front suspension They will be included in our install kit. Pics will be up this weekend.
Old Feb 5, 2005 | 05:38 AM
MADMAN's Avatar
LS1Tech Sponsor
We are using 5/16 flanges, the primaries are 31". They are 16 gauge material. I wont gaurantee that the headers will fit if the motor isnt sitting in the same location as mine is... I am working on pricing next week.
__________________
225-343-9029
Old Feb 6, 2005 | 07:00 PM
OldNovaGuy's Avatar
Default Headers
I am using the S&P motor mounts with mine, so do you think they will work?
Old Feb 7, 2005 | 10:59 AM
MADMAN's Avatar
LS1Tech Sponsor
My mounts are made out of steel instead of aluminum. The S&P mounts made the motor mounts too wide. Otherwise we just copied the S&P mounts in thinner material. The headers should fit.
__________________
225-343-9029
Old Feb 7, 2005 | 10:09 PM
lifted99's Avatar
Sounds awesome. Anything in the works for an install kit into anything else?
Old Feb 8, 2005 | 07:02 AM
Hardtop's Avatar
Madman when will these be available, and do you have any pricing yet? My buddy has a 67 Nova with the Heidts front end. He needs a set of headers bad. Car is painted, motor and tranny done and in. Let me know.
Bruce
Old Feb 15, 2005 | 06:32 AM
MADMAN's Avatar
LS1Tech Sponsor
The pics are up on the headers at www.madmanandcoracing.com/1966c2
__________________
225-343-9029
Old Feb 15, 2005 | 08:06 AM
BBPanel's Avatar
This will work a little better:
http://www.madmanandcoracing.com/1966c2.html
Do you have a pic of the driver's side out of the car? How's the ground clearance? How close is the header to the steering box (that is how much does one have to play with here for clearances)?
Old Feb 15, 2005 | 08:36 AM
MADMAN's Avatar
LS1Tech Sponsor
The oilpan is the lowest point. The headers ar e above the bottom of the pan
__________________
225-343-9029
Old Feb 17, 2005 | 12:26 PM
BBPanel's Avatar
Brian, how about the steering box clearance? Have you established pricing yet> -Bob
Old Feb 17, 2005 | 01:11 PM
MADMAN's Avatar
LS1Tech Sponsor
The steering box has plenty of clearance. We are looking at $1100.00 a set.
__________________
225-343-9029
Old Feb 17, 2005 | 01:23 PM
BBPanel's Avatar
Is that bare or coated?
Old Apr 1, 2005 | 01:50 PM
rsmith's Avatar
Hey Madman, while you are working this Chev II deal up why don't you fab a front crossmember to mount a front steering rack & pinion to help out the people that have junked out stock 40 year old steering on their 1st gens while giving any extra clearance to belt drive system LS1 might need. I have read that 1980's chev II front steering arms reversed side to side with a Chevette rack make steering geometry better than stock when rack is in right place. This would make a great add-on kit for early year Chev II's
Just my $.02 worth
Old Apr 2, 2005 | 09:21 AM
MADMAN's Avatar
LS1Tech Sponsor
We are actually working on a power and manual rack setup.
__________________
225-343-9029
Old Apr 2, 2005 | 10:44 AM
rsmith's Avatar
MADMAN ~~~~~ Check your private messages.
Thankx
Old May 18, 2005 | 11:25 PM
distortion_69's Avatar
Any update on the power racks?
Thanks,
Josh
Old Jun 16, 2006 | 04:04 PM
MAXIT's Avatar
Hey Madman check your PM....
Very excited about your new products.....
MAX
Old Jun 16, 2006 | 07:02 PM
NM156's Avatar
Should be a huge market for those!!
Old Jun 19, 2006 | 04:35 AM
67pete's Avatar
Headers with an after-market front end for the Chevy II?
