fuel relay not getting power so......
ignition source, or is there some other way to rig it up with the pump running only when the engine is running?
the fuel pump has to go thru a relay! you could hook it up to a oil psi swtch but it will have an extended crank time unless the engine builds oil psi very fast.
kevin
Not sure who did your wiring, but bear in mind the fuel pump relay receives 12VDC trigger from the PCM if I recall right...unlike the fans where the PCM switches ground.
If you're getting no 12VDC to the service lug (the one the relay closes to the fuel pump), time to check fuses or fusible links. Maybe a call to Painless tech support to ask where the protection for the fuel pump relay is located will help.
I can tell attention to detail isn't your happy place, but that's what it will take to get it running again and keep it running this time. (hint, check the spelling of your home state)
1. check if theres power going to the fuel pump turn on wire when you first turn the key on. no? thats your problem. trace that wire. (painless harness = 98 PCM.. i dont have the chart for that one or id tell ya the pin.) yes? go on to step 2
2. main FP power going into the relay connector. does it have power? no? thats your problem. yes? move on to step 3
3. you have power, so lets check the relay. take a piece of wire (thicker is better) and shove it into one of the fuel pump wire connector... touch the other one to the positive lead. yea, it might spark.. no it wont shock you, and you only have to do it for a second.... if the fuel pump kicks on... the relay is bad... if it doesnt, you have a bad connection to the fuel pump, or bad fuel pump.. move to step 4
4. shove the jumper wire in all the way... put the connector somewhere where it wont short/fall...go to the back of the car, and see if the fuel pump connector in the back sees power. if it doesnt, the wire is broke... if it does, the fuel pump is bad...
that should do it.
if you just relax, and TROUBLESHOOT the problem, you can solve things like this so fast that they arnt even problems.
