ls1 ecu on caddy motor
that he wants to run an ls1 ecu on for the fuel and spark curves. He's converting it to coilpacks. His extras he's adding to motor are INJECTORS, TB, KNOCK SENSOR, OIL PRESSURE SENSOR, WATER TEMP SENSOR, COIL PACKS, A CRANK TRIGGER TO TIME , A DEGREE WHEEL (PROBABLY THE EASIEST THING TO COME UP WITH AND MAKE WORK), ECT. the basics. He's wanting to know how much a pain in the **** its going to be for him to run the ecu on it, as long as he can tune it to get the curves down. Any help would appreciated. I like his idea of using the ecu for his EFI. Other than that, if it has the correct cam and crank sensor, I could see it controlling timimg. Along with the corect MAP and TPS sensors for fueling.
In regards to the knock sensor, I am not all that worried about it, as long as its using an SAE thread. If it doesn't and I can"t use one from an iron block gen 3, then I can check for aftermarket 3/8 NPT threaded sensors that work on the same voltage as the LSx sensor.
I was under the impression that they used a MAF instead of a MAP sensor. Are the ECU's capable of supporting a MAP sensor, and if so, how many Bar? I don't forsee going over 12psi on this engine, and at that point, I will probably have upgraded to an Electromotive TEC3 to control two seperate fuel systems (gasoline and methanol). Still nice to know if the LS1 ECU would support it, both for this Cadillac and down the road for a gen 3 project that I would love to build.
http://www.holley.com/HiOctn/ProdLin...C950/C950.html
Andrew
If I were going with a "simple" EFI setup like a 350/454 TBI setup on a 4 barrel intake and using a distributor for spark, Megasquirt's current incarnation would be perfect. I love the "open source" feel and attitude to the Megasquirt community, though.
