ditch the electronic throttle?
This will keep us going for a little while! It really is a neat setup. Built in cruise control, no cables to run. The street rodders really love it.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
On my conversion, I will be using an Audi/Getrag 6 speed (mid-enigine application) that has a VSS on the output flange side cover. To run an ETC, does the VSS need to couple into the harness, and if so, I suspect it needs to be a compatible signal. Also, is it required for cruise control? Can you advise?
Thanks,
Andy1
I like to use the VSS signal whenever possible, but you could still run the ETC without a VSS, just no cruise or speedo from the LS1 PCM.
www.speartech.com
