Fuel Pump Help!!
Old Apr 2, 2005 | 01:16 PM
ThirdGenLS1's Avatar
Default Which Fuel Pump!!
Alright doing a ls1 swap into my 3rd gen, using the vette reg./filter and stock fuel tank and wondering what fuel pump should i order. Should i just order the walbro 255 pump or should i get the racetronics pump/harness. The main question is will the harness work with the ls1(plugs into alternator) and is it worth it or should i just get the pump for $108 from Autoperformanceengineering.com.
Thanks a lot
Justin
P.S. - Should i get the High pressure 255 or just the regular 255.
Old Apr 2, 2005 | 05:10 PM
anyone?
Old Apr 2, 2005 | 06:08 PM
crainholio's Avatar
I used the Walbro 255 high pressure pump kit from autoperformanceengineering.com and it's been fine. I didn't pop for the fancy alternator wiring kit, just plugged it into the factory wiring.
Old Apr 2, 2005 | 08:10 PM
thanks a lot, was it hard to install or does it just plug it in, also does anyone know if the wiring kit for the 3rd gen will work with the ls1.
Thanks
Justin
Old Apr 2, 2005 | 08:16 PM
crainholio's Avatar
Thanks
Justin
It was a direct drop-in swap, no mods needed, plug 'n play. How easy it is depends on you...ever dropped the gas tank before?
The wiring pigtail that comes w/ the basic kit they sell plugs directly into your third gen in-tank connector.
The spiffy alternator wire kit should work w/ the LS1 alt no problem.
Old Apr 2, 2005 | 09:27 PM
Alright thanks a lot, think i'll just buy the pump.
Justin
Old Apr 2, 2005 | 10:05 PM
MrDude_1's Avatar
Justin
good choice... lol
that kit is a waste of $$$
Old Apr 3, 2005 | 10:50 AM
Yea looked at it and thought to myself if it was really needed and the answere was no.
Justin
Old Apr 4, 2005 | 12:08 AM
Alright, thanks a lot guys ordered my fuel pump today.
Thanks
Justin
Old Apr 4, 2005 | 12:22 AM
CamaroCain's Avatar
Good deal, I am running the same setup and it seems to be working great.
Old Apr 6, 2005 | 12:45 AM
LS1rscamaro's Avatar
how about an in line fule pump??? is it posible to use it? im doning a swap in my 91any help?
Old Apr 6, 2005 | 02:07 AM
dont see why you couldnt.
