mechanical speedo on T56
Old Apr 3, 2005 | 05:02 PM
dsrour's Avatar
Default mechanical speedo on T56
has anyone modified tail shaft housing for mechnical speedo? Are there vendors who do this? thanks
Old Apr 3, 2005 | 05:05 PM
slow's Avatar
www.jagsthatrun.com having the parts to do this.
If any sponsors do, feel free to edit the link, but i have not heard of it offered elsewhere.
Ryan
Old Apr 3, 2005 | 05:12 PM
crainholio's Avatar
Careful doing this on an LS1. The PCM wants input from the VSS and it's used in logic for idle speed control, fan control, and possibly other loops. If you replace the magnetic VSS with a mechanical one, you'll need to generate a 40K pulse signal some other way.
The JTR conversion is great for fitting a T56 into an older car with correspondingly-old powertrain controls.
Old Apr 3, 2005 | 05:15 PM
dsrour's Avatar
how about having both. ie VSS for computer and mechanical for speedo?
Old Apr 3, 2005 | 08:10 PM
Mark IXZD 150's Avatar
I'm using an Abbott Cable X converter box. It's a lot cheaper than swapping the tailshaft.
Old Apr 3, 2005 | 11:16 PM
dsrour's Avatar
I heard the covetrs don't work that well ie The response time of the servo motor results in a lag and a non natural sweep of the needle. Thats why I was looking at mechanical option
Old Apr 3, 2005 | 11:21 PM
I've never heard that. If true, it can't be any worse than a factory F-body tachometer. Those things really suck.
Old Apr 4, 2005 | 09:01 AM
badjuju342's Avatar
Deranged Rat Fink
That's what I've got , too.
Old Apr 4, 2005 | 09:05 AM
LS69TA's Avatar
Where can I find one of those at? I'm about to be needing one.
Old Apr 4, 2005 | 10:04 AM
MrDude_1's Avatar
http://www.abbott-tach.com/cablex.htm
Old Apr 4, 2005 | 04:50 PM
LS69TA's Avatar
Thanks.
