93 silverado engine swap?
Old Apr 23, 2005 | 09:31 PM
spy2520's Avatar
Default 93 silverado engine swap?
My friend has a 93 silverado cheyenne with a six cylinder. We want to know which engine would be better to swap in, a 5.3l or an ls1? We do plan on modding the engine when we have it. But which one would be easier to swap for.
Old Apr 23, 2005 | 09:41 PM
gen 3 bu's Avatar
Do A 6.0 Swap. You Can Prolly Get The 5.3 Cheapest.
Old Apr 23, 2005 | 10:22 PM
spy2520's Avatar
What is the best way to go about finding an engine. Should we just bounce around to some junkyards and see what newer engines we can find? Definitely on a low budget for this.
Old Apr 23, 2005 | 11:48 PM
PSWired's Avatar
www.car-part.com is a good place to look for engines. Budget at least $5000 for the swap.
Old Apr 24, 2005 | 11:30 AM
spy2520's Avatar
thanks for the info. I've read some other posts regarding the difficulty in making the gauges work with a swapped engine, what is the easiest way to go about wiring a different engine in to work?
Old Apr 24, 2005 | 07:54 PM
PSWired's Avatar
Easiest way is to get a conversion harness from Speartech or painless. This will give you the least trouble. It is not a plug and play job, that's for sure.
Old Apr 25, 2005 | 09:37 AM
spy2520's Avatar
sounds like fun...
Old Apr 26, 2005 | 12:00 PM
spy2520's Avatar
I found some aftermarket gauges for my friends truck.
Dakota Digital P/N VFD3-92C-PU
Will these make wiring the gauges for an engine swap any easier?
pic included...
Old Apr 26, 2005 | 01:57 PM
PSWired's Avatar
I'm not familiar with the Dakota Digital gauges. Check out www.ls1truck.com for swap info in GM trucks.
