Dimensional differences between LSx oil pans?
Old May 6, 2005 | 08:15 AM
'JustDreamin''s Avatar
Anybody got anything else? I've looked for CTS-V stuff, but have been entirely unsucessful. Would like to know what that pan looks like (and the dimensions that go with it).
If not, is it time to cherry-pick the important stuff out of this and post in a FAQ / sticky thread?
'Dreamin'
Old Jul 31, 2005 | 12:04 PM
militant_x's Avatar
This post rocks. Thank you.
Anyone know why the shipping from gmparts direct is 39.92$ on the c6 pan and 28.06$ on the fbody pan? Not complaining about a few dollars just really curious.
Some of you have said the c6 oil pan #12581810 is 'kit'.
Whats in the kit other than the oil pan? do I still have to buy the windage tray seperate? etc.
Thanks
-Chris
Old Jul 31, 2005 | 06:03 PM
ducaT's Avatar
Don't forget the pan on the new impala ss that has the 5.3 in it. I think it's going into one of the Pontiacs also.
It'll bolt to all Ls1 engines, but I have no idea what it (the pan) looks like.
Could be useful in someone's swap.
Old Jul 31, 2005 | 10:07 PM
TJ's Avatar
TJ
'Dreamin'
MTI does a bit with the caddys, you may check there site, or folks that may have had a motor install from them? could be helpful there.
good luck.
Old Jul 31, 2005 | 10:10 PM
TJ's Avatar
TJ
its going to have to deal with the FWD steering components. id like to see one. this pan could open up all kinds of possibilities.
honda civic with an LS1?
Old Aug 1, 2005 | 09:25 AM
2004tr's Avatar
What does the windage tray prevent ?
aeration of oil due to air movement produced by crank ?
I have corvette `winged` oil pan without windage tray can anyone advise of any likely longterm problems.
Old Aug 1, 2005 | 09:46 AM
The windage tray is predominately designed to keep the oil in the bottom of the pan from being whipped into a frenzy by the crankshaft spinning above it (imagine a chef with a whisk beating egg whites). Aeration is part of it, but not the whole, it is also there to try and keep the crank "dry". What I mean by that is the crank has oil in it and spraying off of it (through main journal & rod journal clearances), but the tray is trying to keep the oil spraying off from hitting the liquid in the bottom & splashing back up on the crank (kinda like dropping rocks in a puddle). The less oil that is clinging to the crank, the less drag on the crankshaft (which means more power available to send to the tires). Add to that the air moving around in the crankcase (as the pistons move up and down) and there is alot of potential for aeration too...
Will you have problems? I dunno. Do you push the motor hard or just piddle around with it at low rpms? That will have some impact. If its easy, I'd suggest getting the tray and putting it in (maybe even if its difficult). The tray comes as standard equipment on all of the motors (even the lowly truck motors get one) so GM thinks its worth the money, even for trucks.
BTW, the truck, vette, and f-body pans all take a different tray. Can't speak for the other variants.
'Dreamin'
Old Aug 1, 2005 | 10:10 AM
2004tr's Avatar
Dreamin`
Thanks for that, I will look out for a tray 12558189 as listed in this thread.
Old Aug 1, 2005 | 08:10 PM
TJ's Avatar
TJ
if its in the car, i wouldnt drop a pan to put a tray on. it it not 100% needed, but it does help with a few HP.
good luck.
Old Aug 20, 2005 | 10:46 AM
FastKat's Avatar
I am very curious about the C6, Impala SS/Pontiac GP, and CTS-V oil pans... I looked at the drawing listed on this post and I didn't see any pans that looked like they'd fit my application. If anyone has or knows where I can get the dimensions, please chime in!
Old Aug 22, 2005 | 11:03 AM
There is a thread and pic of the C6 pan somewhere in the LS2 / LS7 section. I know, 'cause I've seen it there. I'll look for it after lunch. You're welcome to search for it yourself if you'd like.
I haven't seen anything on the CTS-V pans or the FWD cars' pans as of yet.
Edit: Went looking for the C6 pan pics, found this thread: https://ls1tech.com/forums/generation-iv-internal-engine/368676-will-ls2-oil-pan-fit-ls6-block.html Even has pictures.
'Dreamin'
Old Oct 5, 2005 | 03:59 PM
  #32
shifty`'s Avatar
Hey, chiming in a little late, but ....
99+ Chevy K/C truck oil pan: GM part #12560393 has been replaced by GM part #12579273! Just a note for others.
I had to find this out the hard way.
Old Dec 20, 2005 | 09:20 PM
  #33
82lt1's Avatar
Did anyone ever find or make a diagram of the LS2 oilpan like the ones on the first page of this post?
Thanks,
Todd
Old Feb 8, 2008 | 05:58 PM
  #34
SonnyG's Avatar
Default Oil pan pics please
Can u send me pics of the different oil pans? Thecarguy84@live.com
In the midst of an lsx 240sx swap......
Old May 18, 2008 | 06:43 AM
  #35
project_re's Avatar
Default Ls6 ctsv oil pan
Ls6 ctsv oil pan
I also need Dipstick & Dipstick Tube part numbers
