Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro Fuse Box Diagram<br>Important information to help you understand your Camaro.
fuse box wiring diagram
I have searched until i cant stand it any longer
does anyone have a copy of a diagram for the under hood fuse box? i am planning on using it in my swap for all the realys and fuses but i could use some wiring help.
any advice or info would be great.
thanks
chris
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
thanks
chris
Originally Posted by SatisTraction
Thanks for the input. I actually dove into it and figured it out. It is really very simple. all i have to do is hook up THREE wires and my LS1 will start!!!!!!!!! I plan to make a simple guide to help others out real soon!!!!
Hey I'm trian to use the factory harness form a 2002 camaro with the ls1 in my `1986 camaro i have the entire car and have managed to remove all the headlights and abs and brake light wirring from the harness but now i have the harness hooked up in the car all is good fuel pump runs dash lights up everything is great but nuthing turns over when i push the key to the crank position and i was wondering what fuse block has the starter wires??? i know the large purple from the block is for the started i belive but i cant figure out why when i hit the key nuthing happens I am assuming that i am missing a relay activation wire??? what wires do u hook up in ur set up to make the car run ????? im hoping something will help me out as i am planing on using both fuse blocks for relays and fuses thanx for any info in advance!!!!
i havent removed any of the wires from the fuse panels that run to the computer at all it seems i forgot to ground one relay on the power block panel as well as not giving power to the activate wire on the starter relay that the large purple wire runs out of
BTW I still have the wirring in the parts car with all vats wirring hooked up and so on... what is that yellow and black wire from the fuse panels for? i see it goes to the computer but what is its ""purpose""
o ok then well it is still hooked to the computer and now that the engine is turning i dont imagine being a problem.... I do still have a no start situation tho witch is very confussing because all systems are go but no runnning.. could this be the vats interfearing ??? and i suppose the only way to get around it is to have the vats removed???
ok i have just tested everything again and it seems i was wrong earlier i donot (no) have spark anywhere none of the oils are firring??? i thought the vats disabled the fuel injectors????? Am i wrong or am i facing an entierly different problem??? and if i am where do the coils get their power form? correct me if im wrong again but i thought the were powered by the computer... please help me all info welcome
hahaha ok well whitch fuse box we talkin bout now??? the one in the cabin or one of them under the hood???? and if underhood again witch one the one with the main power hook-up form the batery or the other one??? thanx
ok ya thats the block i dont have the cover for it was throwen away when the accident was cleaned up if anyone has a pickture or diagram of this fuse panel it would be greatly appretiated.... i have no picture telling me what fuse or relay is for what thanx
LOL your gona hate me guys but i figured it out... when i was removing wires from the fuse panels and such i managed to cut a ground wire for one of the relays and well i hooked it up and instant start hahaha thanx for the input tho ill end up looking back at it as i havent quite figured out witch conectors are the c100 c101 and such but im getting there.... thanks again i just love figuring out wirring its soo fun. btw does anyone know if the body controle modual has to stay in line to make the vehicle run and what exactly it does??????
so if i get vats removed i can take that black box outa the wirring harness???? if so that would simplefy things alot more hahaha if the vats is removed as well as that box. is that all the body controle modual controls does is the vats casue as it stands i have to have that pluged in or it wont start.....
