Started it up today!
Old May 30, 2005 | 07:37 PM
PSWired's Avatar
Default Started it up today!
I finally started my 1995 chevy silverado with a LQ9 6.0L engine and 4L80e transmission today. There's no exhaust on it now, and there are no driveshafts, so taking a ride is about a week off. I also need to work out an air intake system. The thing has a comp 212/218 cam in it, you can hear it in the video. So far things are looking good!
Video:
http://www.pswired.com/95silverado/p...LQ9startup.wmv
Old May 30, 2005 | 07:44 PM
ls1_chevelle's Avatar
what are you planning for an intake?
Any pics?
-Matt
Old May 30, 2005 | 08:23 PM
PSWired's Avatar
Plan to get a 96-99 vortec 350 airbox that mounts between the battery and coolant resivoir, then run PVC ducting (painted black) to th throttle body. Going to pick an airbox up from the junkyard this week sometime. I will get some pictures tomorrow when it is light outside again.
Old May 31, 2005 | 07:59 PM
PSWired's Avatar
Here are a few pictures:
Old Jun 5, 2005 | 08:22 AM
Terry'sToy's Avatar
might I ask what you used for motor mounts?
thanks
Old Jun 5, 2005 | 09:50 AM
jimmyp's Avatar
i got chills Only a few more weeks and my fuel cell should be here, and I will be starting mine up for the first time also. Hopefully it sounds half that good!!!!! Lemme know what kind of mileage you pull out of that...i may upgrade to a 6.0 down the road.
Old Jun 5, 2005 | 10:01 PM
PSWired's Avatar
thanks
I built my own adapter plates out of 1/4" hot rolled steel using templates I found on the net. The plates adapt the 4 bolt mount pattern on the gen III block to the 3-bolt pattern on the old SBC mounts.
Old Jun 5, 2005 | 11:06 PM
Terry'sToy's Avatar
Thank you very much!! I'll be doing something similar. Good Luck with your project.
Old Jun 6, 2005 | 03:37 AM
Gb0dy's Avatar
looking good, what kind of power does the Lq9 make? like mid 300's? whats the truck going to be? just a import stomping truck toy?
Old Jun 8, 2005 | 05:43 PM
PSWired's Avatar
The LQ9 makes 345 HP in its stock application in the Escalades. Most aftermarket companies that sell them with a PCM that has been modified report 400 HP dyno readings. Mine also has a 212/218 cam so I expect to have somewhere over 400 HP at the crank.
The truck is just going to be my daily driver. It has to be reliable, get decent mileage, and have all the comforts of a nice vehicle.
BTW, here are pictures of my mount adapters:
Old Jun 9, 2005 | 06:22 PM
BigTex's Avatar
Now we're getting somewhere! Thats going to make a fine daily driver.
