still no spark.....
Old Jun 9, 2005 | 11:56 PM
SICMARO's Avatar
Default still no spark.....
do i need to have the neutral safty switch hocked you to get spark to my coils. i really dont need the nss but if it needs to be hooked i guess i can. or can i ground it.
Old Jun 10, 2005 | 11:29 AM
LS69TA's Avatar
I had to bypass mine b/c I hadn't hooked it up on the tranny. That was keeping me from spinning the motor over.
Old Jun 10, 2005 | 11:50 AM
Klortho's Avatar
There is a wire that would have been in the C100 connector that is pink that gives power to the coil when the ignition is turned on, I would verify that you have 12v to the plugs going to the coilpacks.
Old Jun 10, 2005 | 02:32 PM
LS69TA's Avatar
If it won't fire after it spins over, make sure the 12v wire you are using for the coils has 12v DURING cranking. The one to the coil in my Painless kit wasn't 12v during cranking for some reason, so check that out as well.
Old Jun 10, 2005 | 04:51 PM
SICMARO's Avatar
i have poser to the coils with the ignition on, but i havnt checked to see if i have power under cranking. if i dont have power under craking what do i do to correct that?
Old Jun 10, 2005 | 07:04 PM
12thstreetjunkman's Avatar
definetly a good place to start, I spent a day on my rx-7 only to find that I didn't have power when cranking.
Old Jun 10, 2005 | 10:30 PM
SICMARO's Avatar
OK i have power to the pink wire on each injector under cranking!! what else could be my prob?????
Old Jun 11, 2005 | 10:33 AM
LS69TA's Avatar
Double check your fuses in the fuse block. I had a blown fuse and I swore I checked all of them twice. I also had a bad ground from the motor to the car itself.
Old Jun 11, 2005 | 11:52 AM
Klortho's Avatar
And there should be two sets of wires going to the PCM with power, one ignition on, and one bat all the time. I was chasing the same problem with my LT1 and found out that I didn't have one hooked up. I had coil power, but nothing else
Old Jun 11, 2005 | 11:55 AM
SICMARO's Avatar
im starting to think the problem is in the crank position sensor.... but im not sure.
Old Jun 11, 2005 | 05:32 PM
Jones'n's Avatar
Have you tried to get a scan tool to connect to the computer to see if any readings are there?
