99 Trans Am LS1 wiring problems
Old Jul 5, 2005 | 01:33 PM
OllyTB's Avatar
Default 99 Trans Am LS1 wiring problems
Righ then chap, i'm asking for help from across the pond. I have a 99 trans am LS1 engine i have it in my conversion and want the engine running properly before the rest of the car is wired. The Engine starts and runs for about 2 seconds but then stalls out. any ideas? is this mechanical/installation or an electrical issue. i basically need the engine running on the stand but it keeps stalling. any help would be greatful,
cheers
Olly
Old Jul 5, 2005 | 05:46 PM
VTESPEED's Avatar
Your problem is the VSS is not turned off.
Old Jul 5, 2005 | 07:28 PM
crainholio's Avatar
I assume you meant VATS.
Not that there's a software switch to disable the Vehicle Speed Sensor anyway.
Old Jul 9, 2005 | 04:44 PM
OllyTB's Avatar
so how do i get round this then as i don't have the vehicle speed sensor!
Old Jul 9, 2005 | 07:34 PM
OllyTB's Avatar
IS there a way i can fool it into thinking all is well or anyone in the uk who can flash the pcm?
Old Jul 9, 2005 | 08:11 PM
ducaT's Avatar
You can get a VATS box from ebay for about 22 USD.
I'm sure they'd ship to the UK.
Wire it into the main harness where the Body control module input is.
Can't remember which pin out.
VATs box has a power, ground and then the output for the PCM.
Pretty simple.
Old Jul 9, 2005 | 08:12 PM
ducaT's Avatar
Forgot about this.
You can wire up one one your own if you want.
I've got the schematic somewhere, but for $22 it's hardly worth the effort.
Old Jul 10, 2005 | 04:21 AM
OllyTB's Avatar
could oyu look out the schematic for it for me please, that would be really good if you could, i'll have a look on ebay though. will the vats box definatley work on a 99 trans am engine?
Old Jul 10, 2005 | 08:24 AM
SUPRYZE's Avatar
If you tell the owner of the auction its for a '99 Trans Am, then he should get you the right one.
As far as pin out, its connector C2 (red), terminal 30 (dark blue wire).
Hope this helps.
Old Jul 10, 2005 | 10:32 AM
Dave_62's Avatar
Search eBay under seller name Bakerelectronics
He has the VATS eliminator you need. They work great-I've been using one in my Cutlass daily driver for two years now.
Old Jul 10, 2005 | 02:29 PM
OllyTB's Avatar
thanks chaps thats a great help, i'll sort one out and go hooning up the road!
Old Jul 10, 2005 | 03:09 PM
ducaT's Avatar
Courtesy of RFERG43, he's the one that gave it to me.
http://www.torquecentral.com/attachm...chmentid=11251
Old Jul 15, 2005 | 11:14 AM
OllyTB's Avatar
thanks chaps excellent!
