LS1, LS2 or LS7 in a BOAT ???
Old Aug 18, 2005 | 06:54 AM
Rune's Avatar
Default LS1, LS2 or LS7 in a BOAT ???
Anyone know if this has been done, or if any company is doing this.
I am looking to get a blown LS7 into a fairly fast boat, goal is 100 MPH :-)
So if anyone could point me in the right directions ?
TIA
regards
Rune
Old Aug 18, 2005 | 07:00 AM
V8_DSM_V8again's Avatar
You are better off with a LS1 stroker... About as much cu/in as a LS7 in a marine application.. Althought I would actually run the newest generation big block bowtie motor 8100 vortec... I would run LS1 coils and a motec, halltech etc EMS with a crank trigger...
There are alot of ways to go but in a constant RPM marine application where TQ is king the BBC rules...
Old Aug 18, 2005 | 07:50 AM
EPP's Avatar
EPP
I haven't see any LS1 equipped boats yet, which is surprising. I was thinking of swapping out the 351 Windsor in my old Correct Craft with an LS1 based engine. Bob
Old Aug 18, 2005 | 08:08 AM
An aluminum block LS1 would help you some...
We ran into the 90mph range with a JET DRIVE on a fiberglass speedboat about 16.5' that had a naturally aspirated 455 olds with a edelbrock manifold, carb and marine cam..... Its all about TQ on boats.... Yes it was nuts...
I still say big block + big belt drive supercharger....
Maybe even a big *** thumper turbo..
Remember air to water intercooing is so easy to do on a boat... You dont need an exchanger or water tank.
Old Aug 18, 2005 | 08:40 AM
Rune's Avatar
I was thinking LS2 or LS7 427 cui, with a Kennebell Blower, BS3 or any other intelligent managment system
Should give me my TQ and RPM scale needed to go fast :-)
But i have not heard of any company making marine parts for the LS1, ie, Exhaust manifoils with water jackets (cooling) etc.
A 427 500 hp and 500 TQ + Kennebell 10 psi should net me atleast 700 Hp and 700 TQ ?
Rune
Old Aug 18, 2005 | 09:03 AM
Rune
That is reason 2 to look at the 8100...
Reason 3 is the rod ratio combined with being a constant RPM application...
Big blocks are popular for a reason in the marine industry.
http://powerandmotoryacht.com/engines/0101vortec/
According to GM you’ll get maximum torque, which is 490 lbs-ft, at 3200 rpm, a popular cruising speed. The high-performance version offers a maximum 420 hp at the rated 5000 rpm, and maximum torque is said to be 505 lbs-ft at 4000 rpm.
IMHO get a 8100 from a yard.. Build it up and drop the compression.. then get ahold of the marine manifolds and air to water the kennebell and belt it for 5000 rpm max... Easily surpass the 700 and it will last alot longer.
Old Aug 18, 2005 | 09:23 AM
LS1GMCTruck's Avatar
Thumbs up More Importantly...
It's the hull that you choose & the rigging, more so than the power sometimes. An air entrapment hull(tunnel or catamaran) has an advantage of 15-40 m.p.h., with the same power...again, this depends on the rigging. Will you be using a straight shaft surface-drive, a sterndrive, a V-drive, a straight inboard shaft, or??? What boat are using? Gar
Old Aug 18, 2005 | 10:16 AM
blacktavert's Avatar
i think the mastercraft ski boats used to use some sort of a version of the ls1 engine, now you can get a 6 liter LQ9 in them i believe,
i think a marine engine is built completely different from a automobile engine, i dont think a engine directly out of a car would last too long, marine engines are built to run high rpms for extended periods of time
Old Aug 18, 2005 | 10:24 AM
Rune's Avatar
Its a 24 feet powerboat, called Hydrolift "fly without wings"
stepped hull, single V hull, but manage 74 knots with a "old" EFI equipped Pocharged 400 cui big block (i think) rated @ 505 Hp.
A C5R 427 can run for WOT 24 hours and still live to tell the tale, so i was hoping to try this route.. :-)
But problem is marine equipment around engine.
Old Aug 18, 2005 | 05:32 PM
The 8100 is 420hp in gm parts trim no forced induction..
Some head work, aftermarket cam and of course the charger and the power you want is easy to make.
Old Aug 18, 2005 | 06:40 PM
grooves12's Avatar
You can get the Vortec 6000 in marine packages from many sources... which is essentially the LQ4/LQ9 used in the trucks... this is a variant on the LS1. The LQ4 was tested/certified as a Marine engine due to their being stricter reliability standards, and they wanted their workhorse truck engine to be super-reliable. The components... other than the computer programming are exactly the same. (With the exception of exhaust manifolds/fire suppressors/and other marine related bolt-ons.)
Old Aug 20, 2005 | 07:30 AM
Rune's Avatar
i found a link regarding LS1 into a boat, seems all marine equipment is available.
I tried to email them, but no reply so far....
http://www.indmar.com/index.cfm?reset=1
this guy has a boat with Ls1 installed
http://www.davedrive.com/v_2000_malibu_lx.htm
Anyone have more info ?
Old Aug 22, 2005 | 02:00 AM
Mystic96's Avatar
I'm all about it...I just need to find a nice finished out hull in need of a motor!
My friend has a 19' Liberator with a 250 Merc Outboard on it, I couldn't imagine something that size or just a bit bigger with the power of a lightweight LS1 pushing it...
Old Aug 22, 2005 | 07:42 AM
'JustDreamin''s Avatar
Hey Guys...
I don't know if the LSx series motor has enough displacement for your speed (and therefore power) goals at the kind of duty cycle that a boat sees. But I do know they're being put in a variety of boats these days.
Here's a link to a previous discussion: https://ls1tech.com/forums/showthrea...manifolds+boat (Use the search function, it really works)
I know it has some info on exhaust manifolds (at least factory ones, don't have any idea if aftermarket ones are available yet).
'Dreamin'
Old Aug 22, 2005 | 11:57 AM
Keith's Avatar
There is a 6.0L offered by GM as a marine engine, so the manifolds should be out there somewhere.
http://www.gm.com/automotive/gmpower...000_marine.pdf
Old Aug 22, 2005 | 01:57 PM
Yes the 6.0l is available as a marine engine, but I don't think the manifolds are usually supplied by GM. I think thats up to the individual marinizer. Not sure of that, though.
'Dreamin'
Old Aug 23, 2005 | 10:33 PM
Spenser309's Avatar
malibu's up to 2006 are availiable with LS1's. However they are getting rid of the option this year.
Old Aug 23, 2005 | 11:32 PM
SmokingWS6's Avatar
Here ya go!
https://ls1tech.com/forums/conversions-swaps/332942-hybrid-pics-mocking-engine-up-not-56k.html
It'll be a heads/cam setup this year. Possibly twin turbo next
Old Aug 25, 2005 | 03:00 PM
mongse's Avatar
I ruin the end of films...
Originally Posted by SmokingWS6
Here ya go!
https://ls1tech.com/forums/showthread.php?t=332942
Heh, I need to get Scott his turbo for that project too. Oops.
Old Sep 6, 2005 | 03:44 PM
Keith's Avatar
I just had an idea.
What about pumping the water that has passed through the block already through the air injection ports or the EGR pickup on stock LSx manifolds?
