picture of howto pull engine
Old Sep 10, 2005 | 01:10 PM
91sbcamaro's Avatar
Default picture of howto pull engine
Does anyone have a picture or some good way of explaining how i hook the engine to my engine lift? its coming out of the top(dont argue) but just wanna know excatly where to put the chains?
Old Sep 10, 2005 | 05:38 PM
Scooter70's Avatar
Bolt the chains to the holes in the end of the heads. If the motor and tranny are coming in/out at the same time, I highly recommend a load leveler.
Old Sep 11, 2005 | 07:39 PM
'JustDreamin''s Avatar
And remember to use the correct fasteners. Most all of the motor is metric.
'Dreamin'
Old Sep 11, 2005 | 08:03 PM
70 LS1's Avatar
Conversion master
What they said. Heads work just fine and a load leveler would have been nice. I managed without, but it was a pain.
Old Sep 12, 2005 | 07:30 AM
I'd suggest you check out Harbor Freight for a leveler.... I got one from there, for I think $20. Not the best piece in the world, but not bad for the money.
'Dreamin'
Old Sep 12, 2005 | 03:37 PM
Scooter70's Avatar
That's exactly where the one in my above pic is from.
Old Sep 12, 2005 | 03:45 PM
ls1_chevelle's Avatar
Auto Value load leveler blows chunks. Don't buy it. I have it and it sucks ****.
-Matt
Old Sep 12, 2005 | 04:49 PM
yodawagon's Avatar
i got mine from northern tool and equipment. it was on sale for 150 with the leveler.
Old Sep 12, 2005 | 05:20 PM
Lesrace82's Avatar
Ihave the harbor feight one and it sucked too. Last time I put the motor in i decided to tryit again with some anti-seize on the threads, worked alot better then just messy if you come in contact with it.
Old Sep 13, 2005 | 01:11 PM
I remember having to do some "massaging" of the harbor freight unit. I think I ended up dremel-ing the holes that hold the threaded rod section....But not real certain, its been probably 2 years since I bought it and mod'd it.....
'Dreamin'
Old Sep 13, 2005 | 01:51 PM
92CamaroReallySlow's Avatar
If your doing it in your home garage make sure you have enough height clearance to get the motor all the way up high enough to pull it out. My garage door was just high enough for me to pull the motor out, luckily.
Old Sep 13, 2005 | 02:41 PM
91sbcamaro's Avatar
ok how do i go about gettin the chains on the bolts in the back of the motor? its in 4th gen camaro so its tucked back there pretty good? and for the front can i put them on the smog pump bolts?
Old Sep 14, 2005 | 06:36 AM
55chevy's Avatar
Do you have enough room to work the engine forward enough to get the bolts in; supported by the chain on the front and a floor jack under the rear of the engine or tranny?
Old Sep 14, 2005 | 10:16 AM
91sbcamaro's Avatar
yea i could prlly do that...but what bolts to attach to in the front? i dont really want to connect them to the head bolts because that would mean i would need to re-torque them correct?
Old Sep 14, 2005 | 10:26 AM
crainholio's Avatar
Use the accessory bracket bolt holes machined into the front-facing surface on the heads.
Old Sep 14, 2005 | 11:24 AM
91sbcamaro's Avatar
Ok thats what i was looking for thank you now what about the rear of the engine? are there some places to hook up the chain without using a head bolt?
Old Sep 14, 2005 | 11:49 AM
55chevy's Avatar
I also used the accessory ones on the heads and the ones in the same places on the back of the heads. I looked for holes that had more surface area around them so I wouldn't break anything. I also checked to see how long of bolt I could use and used the longest possible bolt.
Old Sep 14, 2005 | 12:24 PM
70 LS1's Avatar
Conversion master
Since the heads are aluminum, you can damage the threads if you use a bolt that is too short. You are putting a lot of side load on those threads. I also found the longest bolt possible.
Old Sep 14, 2005 | 02:32 PM
91sbcamaro's Avatar
Yea on the bolt did you just use an accessories bracket bolt or did you get a new one from the store?
Old Sep 14, 2005 | 04:15 PM
01PewterWS6's Avatar
Anyone remember the size on the bolts?
Gotta pick some up at a hardware store, and dont have any metric bolts at home to sort thru and try...(nothing that large either)
Also the size for the tranny to block bolts, so i can stick it on a stand
