Name that part
Old Oct 16, 2005 | 11:11 AM
LS1Cobra's Avatar
Default Name that part
Guys,
I am working on the wiring harness for my LS1 motor now and I need help identifying these electronic parts and their functionalities.
1. Here is a link for the first part. It is inside the car.
http://memimage.cardomain.net/member...2079260_60.jpg
2. This black box is next to the PCM: http://memimage.cardomain.net/member...2079260_61.jpg
3. These 2 are inside the car near the center console.
http://memimage.cardomain.net/member...2079260_62.jpg
4. This part is at the bottom of the steering column:
http://memimage.cardomain.net/member...2079260_63.jpg
Thanks for the info guys..
Old Oct 16, 2005 | 12:25 PM
patrick_rodgers's Avatar
Can't identify any of them, but it would help to know what car and year they came out of.
Old Oct 16, 2005 | 03:05 PM
Stu Cool's Avatar
#2 looks like a Throttle Actuator Control (TAC) for an Electronic Throttle Control (ETC) also called a drive by wire throttle. It should have one set of wires going to the gas pedal and the other goes to the ECU.
Just by their location, #3 may, and I emphasize "May" be inertia sensors to control your seat belts. Is this motor our of a truck with seatbelts built into the seat backs?
Hope that helps
Pat
Old Oct 16, 2005 | 07:00 PM
redbandit98's Avatar
i cant really see that black box very well..dont know what it is or what the one by the steering column is..im pretty sure the two by the console are the stepper motors that control your dampers on your hvac. When you switch from top to bottom vent or from defrost to bottom etc..those little motors are what moves the "Damper doors" and allows air to move from the vents up top to the floor or vice versa..if thats not what they are they look identical to everyone ive ever seen,. i cant tell how big that first pic is..it could be the airbag module.
Old Oct 16, 2005 | 07:15 PM
72ChevelleConv.LS1's Avatar
Steering one is for locating the center of the colum in a corvrtte. the first guy has the correct idea for the black box.
Why do you want to keep all of the parts for your swap?
Old Oct 16, 2005 | 07:22 PM
70 LS1's Avatar
Conversion master
#1 is probably the Body Control Module
#4 is the steering position sensor used for the active handling system on a C5.
Old Oct 16, 2005 | 09:55 PM
LS1Cobra's Avatar
Sorry I forgot the harness is out of a 98 C5 Vette. I do not want anything that I will not need. I already cut out the stereo system wirings, ABS and air bag systems. Next will be the HVAC system. I also forgot to mention that I want to use the C5 instrument clusters so that I won't have to convert any of the sensor.
What functions does the Body Control Module control? Sound like I don't need the green ring around the steering column.
Thanks for your help guys..
Old Oct 17, 2005 | 09:09 AM
70 LS1's Avatar
Conversion master
Let me know if you want to get rid of the TAC and steering sensor.
Old Oct 17, 2005 | 01:26 PM
Earl Filter's Avatar
If they have 8-digit part numbers on them, enter them at gmpartsdirect.com, and you might get a description. Or, you can go to yahoo or google, and enter just the 8-digit part number, or put "GM" and then the part number, and you'll get hits that have descriptions.
Old Oct 17, 2005 | 07:19 PM
LS1Cobra's Avatar
Earl,
Thanks for the info. I will try that .
70LS1,
I will sell it to you after I got the car running and make sure that I really don't need it.
