**NEW** LSx conversion oil pan
Thank you for the reply and clarification. I wasn't bashing... merely commenting.
Does the stock LS1 pickup work with your pan?
BTW- I use a Camaro oil pan and guys that road race with the stock 5.5 quarts have suffered from the oil pickup getting uncovered and then killing their bearings and requiring a rebuild. The solution they have found is to overfill it to 6.5 to 7 quarts. That is what I do as during high g force sustained turns the oil walks up the side of the pan and the pickup gets uncovered I have read multiple times.
I didn't really understand your statement that the LSx engine only needs 2/3 of the oil capacity compared to a Gen 1/2 SBC. Can you clarify?
I look forward to purchasing your product when it is released.
Thank you,
Mark
The oil system of the LSx engine was a clean slate design and was developed to use a lesser amount of total oil capacity. The oil pump is a more efficient gerotor design that is driven off the crankshaft snout at the front of the engine. That coupled with a roller camshaft, which requires less oil to operate (basically the top end) and that it is a 'priority main' oiling system, changes the amount of oil required for operation.
The GenI and II's were just the opposite (except one version of the big block and the bow-tie blocks)..... they oiled the cam first, and then rods and mains. Lack of control and over oiling were part of the 'splash' luberication and cooling of the older blocks.
The motor has a windage tray, priority oiling and a gerotor pump no matter what kind of pan it has on it.
The issue is the pickup becoming partially or fully uncovered under lateral acceleration. From what I can see, this looks like a pretty decent design.
Chicane, can you list exactly what you get for 499?
I assume that is the pan, a new gasket, and the fasteners, did I miss anything?
Thanks...
The pan kit includes:
1. OE GM oil pan seal
2. Stud fastner kit
3. Constant radius oil pick-up
4. Pan, which include windage tray, trap doors, return bungs for TT set-ups, oil temperature bung and two -10 constant radius bypass tubs for remote oil filter and/or a remote oil cooler.
Nice Duc. Too bad I am in the middle of building a house and expecting our first.... or Id have a 996R in the garage next to the hotrod.
2nd measurement of front of shallow sump area to deep sump area is 10.5"
back of pan to front of deep sump is 9.5" and depth of sump is 4.5"
Tyler
1) You stated the motor will sit low and as far back as possible. I will be running an '02 F body LS1 and drive accessories in a 1st gen F body. Will the alternator clear without having to knotch the frame?
2) I read in previous posts that you are coming up with an upper a/c mount kit. Will this be for F body drive accessories? If so, ETA on its release?
3) Just for my piece of mind. I'm planning on running a unisteer rack setup and am I right to assume your mount and pan will clear the mentioned application.
Thank you for your assistance.
2. Its actually a lower mount AC bracket and it will originate off of the Y-body components. This however, is still in development and may change to the F-body or maybe some of gthe F-body components.
3. Dont know about the uni-steer. We dont do racks, because you gain nothing from running one... except to say that you are running one. Our new 670 steering gear (we feel), is actually better than any rack you could stuff into this chassis...... next to an Appleton...... which is not an "on center" type rack unit. As for pan clearence, I could only assume..... that it will. Seeing how the products were created using 'worst case' fitments on all accessories to include the old saginaw steering gear and linkage..... an unmodified stock sub frame and a McLeod scatter shield.
We however, dont like to assume, so to that I can give you no difinitive answer.
Tyler
