5.3 to turbo 400 questions
Probably have to fab up your own motor mounts, shouldnt be too hard...
th400 bolts up just like a th350 does, all you need is a tci flexplate(stronger than the flimsy stocker) and a torque converter spaced out for the combo ls1/th400/th350.....
Originally Posted by superjeep
How much of a spacer do I need to put between flex plate and the torque converter?
If you dont(and get a standard length shaft on the converter), the same spacer you need is used on the trucks
Heres the PNs
crank spacer: 12563532
c.s. bolts (6): 12553332
I want to put a 5.3 to a turbo 400. Has anyone did this? Or know of a web site? Also motor mounts to put it in a jeep frame?
You will need a crank spacer to get it to up unless it's an early 99 5.3. Why not run a 4L65E trans. better first gear plus over drive and plenty of beef! Plus your PCM should control it!
Originally Posted by Bo185
Advanced adapters has motor mounts for Gen III into a jeep! Advance Adapters
