Temp or Oil Sender adapter 1/8 NPT ---> Metric
I found a very useful adapter kit with 5 different fittings that will connect a 1/8 x27 NPT sender to M10 x 1, M12 x 1.5, M14 x 1.5 and M16 x 1.5 and 1/8" x 28 BSP. This will enable you to put a temp sender in the passenger side head without drilling or tapping. Also some aftermarket gauge manufacturers are stocking 12 mm senders now. Check with your gauge company.
It is made by EQUUS, part number is #6848. Cost was less than $8 plus tax. I got it from my local Auto Parts. Much less expensive than the $16.50 for one fitting from one of the conversion specialists.
I will add this to the FAQ
Pat
Pat
