A4 to a M6
Old Jul 16, 2002 | 09:25 AM
PewterZ's Avatar
Default A4 to a M6
Has anyone out there put a M6 in an A4 car? What did it take? Is it as simple as swapping the tranny's and PCM's?Thanks!
Old Jul 16, 2002 | 10:09 AM
O-Ace's Avatar
Default Re: A4 to a M6
Also interested except I have a C5
Old Jul 18, 2002 | 10:24 AM
jeromio's Avatar
Computer will throw codes since it will think the A4 is broken. The crossmember is different too. Obviously there's the hydraulics and the pedal assembly too.
The C5 would be much harder. I don't have one, nor have I ever worked on one, but The list of required parts is much longer and much of the car would likely need to be dissassembled. For an FBody, I'd guess it's a one day project, but I suspect the C5 would be much more of an ordeal.
Old Jul 19, 2002 | 11:16 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
We did an M6 to A4 here in the shop a couple weeks ago, so I've kinda done what you are wanting to do. This was on a 2000 SS. Everythings jeromio says is correct, along with the flywheel, flywheel bolts, we filled a whole in the tunnel with a piece of aluminum so you would be CUTTING a whole for the shifter and boot. I then added the required harness to operate the A4, you would be adding a little bit of a harness for the M6 (at least for the reverse lockout and the backup lights, nobody wants CAGS!). To do it properly, there is also a wire from the clutch pedal to the PCM/cruise control so that your cruise control operates properly and SAFELY. I then reflashed the PCM as an automatic and used LS1 Edit for the performance changes needed (high stall converter and off road Y-pipe). That'll about do it!!
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jul 19, 2002 | 11:19 PM
Speartech's Avatar
Actually you'd be cutting a hole in the trans tunnel, not a whole! <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
__________________
www.speartech.com
