NEED HELP PLEASE!
Old Jul 17, 2002 | 01:41 PM
COBRA.LS1's Avatar
Default NEED HELP PLEASE!
I have an engine sitting on a pallate waiting for a kit car and to ensure it runs good I tried to fireit up. I have the entire car wiring harness with column and key. It does run roughly but, I noticed a spark is deliverd when the key is turn on without the starter moving. I have all the engine sensors hooked up as far as I know including the O2 and MAF. Anyone have a reason why or what am I missing.
A new forum member and first time LS1 owner.
josh
Old Jul 18, 2002 | 01:18 PM
WILWAXU's Avatar
Default Re: NEED HELP PLEASE!
I just bumped up your other nearly identical thread. I'll move this one to our Hybrid, Conversions section.
<small>[ July 18, 2002, 01:20 PM: Message edited by: WILWAXU ]</small>
Old Jul 19, 2002 | 04:34 PM
bgreen's Avatar
How do you have it wired? Specifically, what do you have supplying the coils with power? The lead supplying power to the coils is at a plug that would be left undone if someone supplied you with an engine harness, and no body/chassis harness(es). I had to splice that wire(wires? I forget now) to supply power for the coils.
Do you get a spark at every coil? Or which one?
Considering you are sitting on a palatte, grounding the motor etc may be an issue.
Brian Green
89 TTA
01 Jeep TJ (to be GM powered in the fall)
