LS1 in a 3rd gen exhaust question.
Old Nov 8, 2005 | 06:35 PM
exodus's Avatar
Default LS1 in a 3rd gen exhaust question.
The manifolds that were on the engine that I am using for the swap are screwed, and since I have to change them out, I really want to get headers. I know the last that I heard, someone was working on a set for production. Can anyone tell me if they are on the market yet, and if so from where. If I cant find them, then I will need a set of the 01 or 02 manifolds for the LS1 if anyone has some they are will ing to part with. Please let me know. Thanks for your time.
Chris
Old Nov 8, 2005 | 07:25 PM
shr00m-dew's Avatar
Hawk's third gen parts has their set out. Long tubes, with or without cats and y-pipe. Expensive, but your only option.
I'm going with the 01+ manifolds because I can't lose any more ground clearance with longtubes.
Kevin D.
Old Nov 8, 2005 | 07:40 PM
Dave88z's Avatar
I am in the same boat with the header situation. I got a 6.0L going into my 88 IROC. Everyone tells me Hawks lt's are the only way to go. I have tried e-mailing a few header companies (KOOK'S!!) but they never got back to me. Want to see if any 98-02 lt's will fit.
Old Nov 8, 2005 | 07:59 PM
exodus's Avatar
They will not fit, I tried a set of pacesetters, and the hooker super comps. Believe me, it aint gonna happen!
Old Nov 8, 2005 | 09:51 PM
StevenK's Avatar
The 4th gen runs the subframe rails different than the 3rd. The 4th gen headers point out towards the side of the car and will run right into our 3rd gen frame rails. Hawks come down then straight back, doesnt give you a ton of room to work with, but at least it makes it physically possible to get exhaust under there.
Considering how much it would cost to have custom headers made, the hawks arnt that expensive.
Old Nov 9, 2005 | 07:13 PM
exodus's Avatar
I took a look at the haws headers, and they look great, the only thhing is that they are a little out of my budget still. I think that I will be going with the o1+ manifolds. If there is anyone here that has done the LT swap in their car and has a set they are willing to part with, please let me know.
Chris
Old Nov 11, 2005 | 12:03 AM
89FormulaLS2's Avatar
exodus, shoot me a PM. I'll have to look, but I think I've still got a pair of 01 manifolds out in the shed with the "spare" LSx parts.
Old Nov 11, 2005 | 12:29 AM
SeeYaSucker's Avatar
Try a set of MAC midlengths for 4th gen. I think they will fit, but you will have to have a custom Y pipe made, unless your going to run duals.
Old Nov 11, 2005 | 03:52 AM
4th gen Mac Midlengths will NOT fit a 3rd gen f-body. It's already been tried by Speartech. Hawks are the ONLY production headers that will fit, other than factory manifolds.
Old Nov 16, 2005 | 01:45 AM
skippydn's Avatar
[QUOTE=shr00m-dew]Hawk's third gen parts has their set out. Long tubes, with or without cats and y-pipe. Expensive, but your only option.
I would not pay $750 for a set of headers that may not fit.
Old Nov 16, 2005 | 07:54 PM
StevenK's Avatar
[QUOTE=skippydn]
Then go spend even more on something custom.
Old Nov 16, 2005 | 07:59 PM
shr00m-dew's Avatar
Who said they wouldn't fit?????
Kevin D.
Old Nov 17, 2005 | 02:24 AM
skippydn's Avatar
[QUOTE=StevenK]
Some people have connections.
Old Nov 17, 2005 | 02:25 AM
skippydn's Avatar
Kevin D.
Read my post, I said MAY. Do a search on some of the boards and some people complain they don't fit.
Old Nov 17, 2005 | 07:16 AM
crainholio's Avatar
For someone that just joined a couple of months ago and still has a "stock for now" car, you appear to be a wealth o' knowledge on the subject of LS1 swaps...
Old Nov 17, 2005 | 10:18 AM
skippydn's Avatar
For someone that does not know **** about somebody's car or that person, they do run their mouth a lot. Just b/c my sign says stock, does not mean it is. And I have helped people do the ls1 swaps, jackass. So I would think I know a little bit about the subject.
Old Nov 17, 2005 | 02:23 PM
crainholio's Avatar
Hey, if you're into lying in your sig then that's your issue. One of several issues from the looks of your grammar and your demeanor.
You'll live a happier life if you get help. I'd start with the misdirected anger issues, then the Freudian projection, and finally with getting grammatical skills up to high school level.
Old Nov 17, 2005 | 02:56 PM
TJ's Avatar
TJ
im running a set of z06 manifolds on mine, but i can tell you the ONLY WAY they are going to fit is with a tubular k member.
there is NO WAY they will work with a stocker.
if you can find a set for free, or really cheap, id try them.
ive been almost 96mph in the 1/8 on these manifolds with a 3" y pipe.
im looking at a set of stainless works headers(hawks) right now. should have them on my car within the week.
i hope they fit!
pricey, but when you account they are all stainless, its a bargain.
Old Nov 17, 2005 | 06:59 PM
StevenK's Avatar
skippy, if you have connections to get custom exhaust, more power to you
crainholio, you arnt even being slightly usefull in this thread, your just stirring the ****, so kindly STFU and get out unless you have some usefull input.
TJ, those are some pretty ncie numbers. I've got mine installed in teh bay, and the left side header hits the fuel lines, but no big deal I can relocated them, the pass side clears just fine. I think you will be happy with them.
Now if I could just my car to fire up I would be able to hear em
Old Nov 17, 2005 | 08:10 PM
TJ's Avatar
TJ
bruce assured me there was no issue of the fuel lines hitting on any of the cars he had them installed on.
he said the closest one was about 1/8 off the line, but none were touching.
im running aftermarket AN line (near) the stock location.
my motor is moved back an inch - inch and a quarter, do you think ill have a problem with them hitting the firewall?
ill prolly be starting on it tomorrow if my brake pads for my 4 wheeler ever show up. got it apart and ready, so its gotta be finished 'for my car gets the go ahead.
