ls1 in jeep
Old Sep 17, 2002 | 11:31 PM
justin sutton's Avatar
Default ls1 in jeep
I want to put a ls1 in my 02 tj.I was wondering if I bought the complete engine and harness would I need a kit like the painless harness also?
Old Sep 17, 2002 | 11:46 PM
LS171Malibu's Avatar
Default Re: ls1 in jeep
I would say yes. I recieved a harness with my engine, but I went with Street and Performance for simplicity and VATS.
Old Sep 17, 2002 | 11:49 PM
I was also wondering about the chip in the key.If I do decide tho program or ls1edit the thing will I have a problem.I was also wondering about how much the harnesses are.
Old Sep 18, 2002 | 05:04 AM
VATS is vehicle anti theft system. Street and Performance harness has a module that bypasses it. One cool thing is that you can unplug it or wire in a switch that will keep the engine from being started, no way to hot wire this. The harness are less than a thousand dollars.
Old Sep 18, 2002 | 11:40 AM
Chris Spiess's Avatar
LS1Edit can remove the VATS function from the PCM.
Old Sep 18, 2002 | 11:45 AM
Man, that is great. I could have saved alot if I knew about that.
Old Sep 18, 2002 | 01:05 PM
Yea I was thinking $1000.00 is high for a harness.I am not shure what the painless harness costs but I know its not a grand.
Old Sep 18, 2002 | 10:12 PM
John B's Avatar
Moderator
For the overpriced S&P harness you can afford to have Speartech rework your OEM harness and buy LS1_Edit!
Old Sep 19, 2002 | 01:30 AM
graygmc's Avatar
yea i raced a 99 Jeep with a like 98 vette motor. that thing was fast. ran a 13.9 with stock tires and tranny. i believe one of the front tires came off the ground when he shitfed into 2nd. i was impressed.
Old Sep 19, 2002 | 08:47 AM
bgreen's Avatar
I'm doing a truck motor with 4L60E in my Jeep TJ.
The guy that ran a 13.9 in his TJ... I have emailed him and have pics of his rig up on my site. Lemme dig 'em up...
Ah yes, here they are:
http://www.chitownsyty.com/bg/jeepstuff/TJLS1/
Here's the page I've put together for my swap so far:
http://www.chitownsyty.com/bg/jeepstuff/v8_tech.htm
I'd say going with LS1 edit is a GOOD idea.. if you set codes for any reason, you can disable them, not to mention the custom calibration mods you can do.
<small>[ September 19, 2002, 08:48 AM: Message edited by: bgreen ]</small>
Old Sep 19, 2002 | 01:05 PM
I was thinking of going to the junkyard and swapping my motor and trans.I dont have but 8400 miles on it.
Old Sep 19, 2002 | 01:12 PM
bgreen's Avatar
What are you looking to do with your jeep? Offroad or race?
What is your budget?
What are your goals otherwise?
automatic, jeep 5 speed?
keep stock transfercase?
mileage?
Old Sep 19, 2002 | 01:25 PM
i drive it every day.It has 8" of lift with 36" swampers.I want the 4l60e.As of now I have 373s and have to run in 4th gear because 5th drops off to much.I have 456s in the shop just havent felt like putting them in because I think I am going to swap them for 488s.The reason being is I am going up 2 1/2 more " and putting 37s on it.I like to hill climb and rock crawl.I plan on leaving the 231 for now until I get saved up for a atlas2.Email me and I can send you some pics of it.
Old Sep 20, 2002 | 12:30 AM
Thanks alot Brian.If you run across anything else please let me know.So you are going with the 5.3?
Old Sep 20, 2002 | 12:51 AM
bgreen's Avatar
Yeah I was going with the 5.3, then the 4.8, now I have a line on a 5.3 again.
There are lots of little issues you'll have to consider; I'm pretty sure I've got a solution to all of them so far <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I'm using a regular truck harness that I'll modify to work in my application. I'd rather use an LS1 motor, but they are more expensive than the truck motors.
Old Sep 20, 2002 | 12:53 AM
graygmc's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by bgreen:
<strong>I'm doing a truck motor with 4L60E in my Jeep TJ.
I'd say going with LS1 edit is a GOOD idea.. if you set codes for any reason, you can disable them, not to mention the custom calibration mods you can do.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">do you know the guy who owns that jeep? has he done anything else to it yet. i bet with slicks that thing would be low 13's
Old Sep 20, 2002 | 07:24 AM
bgreen's Avatar
I've emailed him back and forth several times.
I don't think he has much more done now.. he may have been doing something with the transfercase or transmission - he was still using the Jeep 5 speed. I thought it was pretty cool that he was getting 22-24mpg. Beats the hell out of the 16 or so I have to TRY to get in my Jeep.
