6.0L swap???
Old Dec 8, 2002 | 06:36 AM
sleepybu's Avatar
Default 6.0L swap???
I want to swap a 6.0L truck motor in to my 81 Malibu but have some???
-are all the 6L motors the same?
-what's the perfered years to look for?
-how much N/A hp can i get with bolt on's (cam, rr, minor head porting, headers/3"dual exhaust) on a stock program?
-will a ls6 intake work on the 6L? (i don't need the low end tq since my car is 1000+lbs lighter then the trucks)
-can i use the old stile tranys?
-do i have to use the truck computer or can i use a ls1 cp?
I will be doing the swap myself.
Thanks for the info <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Dec 10, 2002 | 09:21 PM
John B's Avatar
Moderator
Default Re: 6.0L swap???
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> are all the 6L motors the same?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Personally I'd look for a 5.7L 2001 or 2002 motor because it will already have the LS6 intake. I don't think the 6.0L vary that much year to year.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">how much N/A hp can i get with bolt on's (cam, rr, minor head porting, headers/3"dual exhaust) on a stock program?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">With only minor heads porting and decent cam 400-420RWHP depending on how the stock program is set-up
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> will a ls6 intake work on the 6L? (i don't need the low end tq since my car is 1000+lbs lighter then the trucks)
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">can i use the old stile tranys?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">do i have to use the truck computer or can i use a ls1 cp </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Since you will be using all of the other 6.0L components you're probably better off with the Truck PCM.
If you need an oil pan and motor mounts to make this a bolt-in installation please e-mail me!
Old Dec 10, 2002 | 09:28 PM
YellowChevy4.8's Avatar
the 6.0L that come in the HD trucks are different than ones in the Escalade and Denali. I think it might be due to higher compression. The horsepower difference is like 20 hp or so. Check out the truck forum for more info, alot of guys are asking questions about 6.0L swaps and whatnot.
Old Dec 21, 2002 | 01:38 AM
taqwache's Avatar
make sure you get a 2001 or up 6.0L. they came with aluminum heads closely related to the LS6 heads but with bigger combustion chambers. the older ones came with cast iron heads.
