Cooling Fans for Hybrids?
I used the fans from an LS1 Z28. I modified the plastic a little. They were $80. from a junk yard, I couldn't get that quality and durability close to that price in the aftermarket world.
Larry M
They are available thru Ramchargers, for about $80 I believe. They sell it in kit form for $100-140 for 2 speed setup with relays and such, but you can get it for $80 for what you see in my pictures.
http://www.chitownsyty.com/bg/pics/syfans/
My Syclone is actually running too cool with these fans now, and they typically run *WAY* hot. Many TurboBuicks are running the same fans, on cars with front mount intercoolers that obstruct the radiator even.
I wouldn't hesitate using these on any LS1 project. Fans, shroud, and all, $80 is a killer deal and they flow some serious air. I had to do some cutting to the fan mounting portion, but I made it look clean. You can do some searching on turbobuick.com for dimensions to see if it will fit, or if you're really hurting, I can do some digging or measuring of my setup.
http://www.chitownsyty.com/bg/LS1tech/fans.gif
I know the image is corrupt, I'll upload a good version soon, but at least this gives you the idea. You may want to call Ramchargers about this, because the expensive setup should have 2-3 relays & all wiring needed to do the 2 speed setup. I just didn't have an extra output from the Syclone ECM to run 2 speeds. I may do it in the future, by using a cheap thermostat type turn on for low speed, and the ECM output for high speed (160-165 low speed on, 185 high speed on, or something like that).
No problems with the fans at all, they work great. They have been used by many TurboBuick guys with no problems that I have heard of. I've had them on the truck for several months now. Word is that they are used by some Chrysler vehicle, OEM, and they have a source to find 'em cheap to sell to the aftermarket. I didn't bother searching any more, since $80 is plenty cheap for me.
Might not work with your application, but I'm not sure if their measurement is from the ends of the mounts, or the end of the shroud. methinks it's the actual shroud width, I'll double check to be sure.
I got the image online from the GM service website <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Gotsta know people. I also have the GM service CD roms, and I think they are on there.
Thanks
I custom built a shroud from aluminum as the LS1 shroud was too wide for the stock Astro rad. Works great.
Any one looking at the Ramgharger fans in BGreen's post, but dont know about measurements.
I just got mine and thought I would post up the measurements.
26.5" X 15.5" these are for the shroud.
and the overall length including the mounting tabs is 31"
